- Sep 27, 2009
- MS Gulf Coast
Before I get into the heart of the matter I do need to provide a bit of history. My current 390X card is an RMA replacement which I received new in the box from Asus when they couldn't repair my old card. When I originally got it I put the 390X in my rig, but that thing was on its last leg so I ending up building an entirely new machine replacing everything down to the case. The only two components I transferred over to the new build were the gpu, still relatively new, and the Enermax 1000W 80+ gold power supply, which was also still pretty new and under a month old. My suspicion is the old motherboard might have damaged the new card.
What is happening is the PC is completely locking up during gaming with a loud buzzing sound looping through the speakers. It has happened twice now and when it does the only option is to hit the reset switch. The first time it happened during COD: AW using the crimson 15.12 drivers, but I suspected a corrupt windows installation. I ended up doing a clean reinstall of Win10 x64 and updating to the crimson 16.2.1 drivers. When I run 3DMark 11 everything is nice and smooth, but I was playing Rise of the Tomb Raider in steam last night which was running fine, but it locked up again I would say 20-30 minutes into the game. No performance issues in the game other than the total freeze up with the looping buzzing sound. The card is not being overclocked other than I have the fans turn up to 40% when gaming.
The least likely scenario, I think, which someone I know suggested is the psu is under-supplying the card. Aside from the fact the psu is practically new I haven't experienced any BSODs, crashes, or errors outside of gaming. I can leave my computer running for hours and everything still works so if it was the psu there should be something else happening in terms of errors indicative that unit is the culprit.
After an analytical series of tests and process of elimination here is what I think is happening:
[-] The display driver is crashing or messing up. One of the reasons I think this is because when I was messing around with the game's settings last night I heard the gpu fans rev up real loud for a couple of seconds before going back down. Also, when messing around in radeon settings the app has crashed twice now. All I have to do is relaunch it and it's fine, but the driver package could be unstable. Finally, I was just reading another thread where a power management feature in the crimson drivers have been causing instability problems for some people.
[-] The GPU is overheating. Unlikely, but still possible. I have a pretty well ventilated case with 3x120mm intake front fans, 2x120mm exhaust top and 1x140mm exhaust rear. Not to mention the card has three fans and they are working. I launched HWInfo and gamed for about 30 min. getting past the point where it locked up last night and the temps it reported to me after quitting were 71°C max and 58°C average. The gpu VRM averaged out at about 66°C as well so from what I can tell pretty normal temps for this kind of card. All of this was with the fans running at 40%.
[-] The GPU is failing. I hate to think that a card I received new in the box could be messing up so soon, but it is still possible if the old failing motherboard did indeed damage it.
If anyone has any ideas I would love to hear them. What seems to be the most likely scenario? I'm thinking about downgrading to crimson 15.12 on the new windows install and see if it still locks up, but I'm also wondering if I should just go ahead and RMA the card.
Feedback is welcomed and appreciated.
