- Oct 11, 2002
- The Empire State
As per AMD's specifications the 390 series of cards are designed to operate at 95C so it's made to run hot.
50s are a good temp for this kind of card with air cooling.
I do have a problem with this statement and don't consider this sound advice [no offense Nebulous]. Advanced power saving features are a nice thought, but the coding within them is flawed kind of making them an "unfinished technology". They sound great on paper and rarely work as well as they should without creating conflict. However, some do work better than others.
TBH I would not disable all of them in the bios. It's just not a good idea for your hardware to have your cpu running in full state even when it's idle. Turning off all of the PWM features should only be done if necessary because they are creating a conflict.
I dislike excessive heat coming out of my case. Tho I'm well aware the AMD gpu's are designed to operate with high temperature, the gpu will start to throttle back to save itself from overheating. This is where the performance starts to take a hit. I like my temps on the cooler side of things and will put a full cover waterblock on my 390 along with another radiator.
I prefer to run my high clocks full bore 24/7. I have no issues or conflicts with my rig, trust me. My only issue is the noise my gpu fans make when I start cranking out a gaming session.
