Crosslhs82
- May 28, 2018
Hi
New to Ocf.com
I'am looking for peltier help.
I live in a 2bdrm apt it has 1 and only able for1 ac unit..
It runs 24/7 in the summer and jacks my electric bill upto $275 a month while the bdrms are getting no help.
I sit at my cpu dripping in sweat.
What i'm trying to do is make a homemade ac unit from vids i've watched on ytb.
It's kinda like a open loop water cooling system.
I have a 24in blade industrial fan with 39ft of 3/8 copper tubing coiled up and attached to the grill, fittings and pond pump running just enough water to keep pump submerged.
It stay's cool for a little bit but then is useless when i can't keep up with the ice keeping the water cold enough. Last week i put in 2-10lbs blocks of ice and 5lbs of dry ice and it was gone in 2hrs.
Will a tec1 12706 peltier 12v 60w 5-6amp with a fx-8350 wraith heastsink or corsair h60 on the hot side and upto 200mm radiator heatsink tank style
on the cold side in a semi closed loop keep the copper tubing cold enough to provide the cooling i'am trying to get. (Where we are not sweating while trying to sleep)
I have the h60, the 8350 and 6350 coolers.
Would i need only 1 tec1 12706 or 2?
If 2 Going with the 200mm tank it would give me the room i need to mount 2 of them knowing i would need 2 power suppls which i can get for $16.00 each and $10.00 for 2 12706's
Attachments would be done with amd cpu retention brackets for heatsink to hot side with the peltier in the middle of the cold tank with the backplate holding all together with longer screws and nuts.
My family and my wallet needs exterme cooling expert help.
But Any Help Would Be Great !!!!!!!!
New to Ocf.com
