- May 10, 2009
Oh they're not good at all for CPU cooling, unless you're in Marketing and trying to sell them. They're horrendously inefficient, as mentioned at least a couple times on the first page of this thread.
The only way TECs are efficient is in space required, for their cooling power they are very very small.
To get more effective at moving energy around than water you're looking at liquid ammonia, something you don't want to muck with.
Water beats all the various liquid coolants out there.
The pump is your enemy, it's putting as much heat into the loop as the TEC is pulling out.
A beefier TEC will solve that problem, leaving just the question of whether the cooling for the TEC can deal with the new improved higher power TEC.
