I was referring to the "socket burn"
No, 8 phases minimum of any decent OCing
I think socket burn and blown MOSFETs are two symptoms of the same too-high current disease. For a board with a low number of phases (even though I don't believe in all the MOAR PHASES marketing bs hype) if there's too much current a MOSFET blows, for a board where a MOSFET will not blow because there is enough headroom in the design the too-high current is delivered to the socket and causes burn there.
Well, the moar phases the merrier, I think.. I remember you saying in an earlier post that you do not run your system near the ragged edge.. But there are lots of people who do. The pics and links posted should be a clear indication that moar phases are better. Maybe 16 or 24 is a bit excessive, but still, you saw what happens with a poor design. And the key here, is that it was repeatable, so it wasnt just a fluke. Just because you have a chip the clocks with lower voltage, doesnt mean the amperage it draws is also lower. Once you start overclocking, everything changes, as Im sure you are well aware
Lots of phases are done because it looks good for marketing and it's cheaper for mobo makers on top of that so it's win-win for them. It's cheaper to make a many-phases design with inexpensive parts than a fewer-phases design with expensive parts. There is nothing inherently better about more phases as long as the circuits are well designed for the application. Obviously we don't see the same exact board with cheap plentiful phases and fewer expensive phases so a direct comparison isn't possible but there *are* boards out there with the fewer expensive VRM design that are perfectly competitive versus boards on the same platform with many phases. The reason for these boards blowing isn't low phase count itself it's that the parts just can't handle the current loads - in other words, not a well-designed circuit.
Could you tell me which of the boards have the fewer expensive VRM design? I want to know so I can choose a board that doesn't blow up when I try to oc the i7 860 that I'm planning to use as part of my rig. Thanks.
