It's been a very long time since I've built and overclocked a computer because my last machine carried me for so long, when I built my current one, it was like I was building my first computer all over again. My last machine was built about nine years ago and based on a Q6600 which I ran at 3.2GHz and a minor flood caused me to build a new machine. I have a rather odd temperature issue with this current build though. Before I go into it, here's what I'm using:
CPU: Intel i7-5820K @ 4.1GHz (125MHz BCLK and 1.25v)
Mobo: Asus X99-A USB 3.1
Memory: 4x 8GB Corsair DDR4 3000 (PC4 24000)
HSF: Noctua NH D15 with both 140mm fans installed
The issue I'm experiencing is abnormally high temperatures as reported by both HW Monitor and Asus' AI Suite 3. They both claim the CPU idle temp is around 40C with a motherboard temp of about 30C. When I run a small FFT torture test using Prime 95, my fans spin up as they should but my CPU temps hit 93C! The system is completely stable but that seems extremely high. Admittedly, I've been out of the computer building and overclocking game for quite some time but isn't 93C excessive and/or dangerous? Airflow is not an issue as I have tried this with the side of my case off and there's only a slight (1-3C) change in temperatures.
I pulled the HSF off tonight and reapplied Arctic Silver 5 hoping that I had screwed that up but nothing changed. I was under the impression that the Noctua HSF was one of the best air coolers available and that my overclock isn't extreme as most 5820K CPUs have no problem hitting 4.2GHz and higher with more voltage. What am I missing? Is there anything I should double check? Or am I wrong and this is normal for current CPUs?
