Try your equation with a time of 65s and a clockspeed of 4.8GHz. This is scaling of 100% efficiency with a performance increase of 100% and a clockspeed increase of 100%. But your equation considers it only a performance increase of 50% and a clockspeed increase of 100%. Your equation is obviously incorrect.That calculation wasn't for efficiency, it was for performance increase. For efficency you take the performance increase that I calculated (17.55%) and divide by the clock speed gain (25%). Then you see that the K10 scales better (77% versus 70% efficiency).
Still using the wrong efficiency equation. The Opteron even with its slightly higher efficiency would not catch the 3GHz Xeon at 3GHz and its doubtful that its efficiency at 2.5GHz to 3GHz would be the same as from 2GHz to 2.5GHz given the nature of WME.WME is far from a clear win. Even if you use the 2ghz Xeon with the 3ghz xeon, you only get 53% scaling efficiency whereas the Opteron has 71%. The Opteron would pretty much catch the Xeon at 2.33ghz (theoretical as there won't be a 2.33ghz Opteron) and then perform as well or better than a Xeon.
Randy Allen promised 2.5GHz by December.So as of right now you could say a Xeon wins, but by November (rumored release of higher clocked Opterons), that won't be the case.
Even if the 2GHz Opteron gets the win for POV-ray, it still only wins in SPECjbb2005 (and will probably lose when its official score is published considering the official 2xX5365 score is over 230,000), POV-ray and Myri-Match while losing in Valve VRAD, Cinebench, Eulers, Panorama Factory, picColor and WME compared to the 2GHz Xeon.I don't see why the 1st test should be thrown out. It's just rendering a different scene, doesn't mean it should be discredited. The only reason I through the 2nd one out is because the program they use is still in beta and obviously doesn't play nice with the NUMA system. I wouldn't hesitate to use those results otherwise, even if the Opteron did lose.
Keep it clean and on topic folks.
quad in action
Something else I noticed in the cinebench at techreport.
Looking at the eight-core results, going from 2ghz to 2.5ghz on K10 yields a 31.1% performance increase meaning a 124% efficiency! Could this be an anamoly? Sure. Could it also be an example of the bandwidth hungry core we hear about finally getting some bandwidth to unleash it's potential? Also a possibility. Personally, I think it's a combination of both. I think in certain examples, the increased memory bandwidth given will allow the scaling of a Phenom cpu to be more efficient than even Barcelona has shown, but I also think something else may be going on in this benchmark we don't know about. Just my observation/opinion.
That's an infinite performance increase. So when somebody runs 100m in 20s, and another person runs it in 10s, is the second person only 50% faster than the first?.Actually 100% improvement would be as close to 0 sec as possible,
So with the correct scaling equation, the 3GHz Opteron would 381s. Still slower than the 3GHz Xeon and that's only assuming it maintains as high a scaling factor.Using the correct efficiency calculations you're looking at a Xeon 2.5ghz pulling in a performance of 444.3s compared to 447s of the 2.5ghz K10 which means the difference is only 0.6%. . . you really don't think a 3ghz K10 opteron wouldn't match a 3ghz Xeon? This is also discounting the poor scaling between 2ghz and 2.33ghz of the Xeon which at this point I don't think is trustworthy.
Based on AMD's recent performance and credibility of AMD rumors, I wouldn't bet on it.Perhaps it will be December, as I said, there are rumors that faster Opterons will be out by late Oct. or Nov. I guess we'll have to wait and see.
Well, then the Myrimatch lead is also slim and regardless, Xeons are still faster clock-for-clock.This is exactly what I said, 3 for Opteron, 5 for Xeon as the WME win is quite slim and will disappear once faster Opterons appear.
And clearly they calculated it wrong like you did. I'm sure a physics teacher will take no more than a few seconds to tell you somebody going at 100 km/hr is 100% faster than somebody going at 50 km/hr.Yes. If you have problems with the equation, go take it up with Anandtech, like I said, they calculated their results the same way; or go argue with a physics teacher as I'm sure they'd tell you the same.
I consider that Myri-Match which performs absolutely poorly with more than a few threads not to say very much at all.You consider a 5.3% performance advantage with a 20% deficit a slim lead(2.5ghz K10 beats a 3ghz Xeon)?
There's enough evidence to make reasonable predictions.It's these kind of open-ended, unqualified conclusions when we have only seen previews of K10's performance that bother me.
Perhaps, but you haven't specified any predictions, you've made unqualified statements based on weak evidence of what you're trying to support.There's enough evidence to make reasonable predictions.
In December the company will be in position to offer 2.5GHz chips. But 25% speed increase will bring only up to 15% performance improvement, said Mr. Allen.
I see a 2Mb L3 in there. What would the cache latencies be? Would the overall latency increase or decrease?
How well do intels core2 scale with 25% increase in clock? I would like to know 2ghz -2.5ghz and 2.33 -3ghz.
