Ok so I started off reading and asking questions. It was so fun sifting through as many threads as I could. Some would say I was a bit obsessed.
Well any this is my build. I tried to take as many pictures of progress as I went but sometimes I just got too into the build and forgot I had free time towards the end of my summer and I had the itch to build something. The drawer on my old desk was falling apart so instead of a $1 fix I decided to build a new one. I thought it would be cool to put a computer inside a desk. I am all too familiar with the old adage that if you have an idea chances are there are others with that same idea. With that I hit the interwebz to see what others had done (why reinvent the wheel when you can just improve on it). I saw a lot of attempts and successes after a good google image search so I started to design my own. I started off with an air cooling idea but just as soon as I finished that design I came across the Cross desk by Red Harbinger. Well that just flipped me on my head! this is what came from that
The original goal did not change. 2 computers in a desk, one to use as a server and the other as a general pc (I don't really game much) but both the builds had to be quiet as a mouse. So I went watercooling...my wallet hurts
I wanted a desk made of wood and somewhat blended in with my furniture. Fun was had
Main PC
Asus Sabertooth 990fx 2.0
AMD FX-8350
8GB Gskill Ares
EVGA Superclocked 660
Corsair Neutron 256GB SSD
EK 660 GTX Full Cover Block
XSPC Raystorm CPU Block
D5 Vario pump/res combo
RX360 Radiator
3 Gentle Typhoon in Push Config
XSPC 7/16 x 5/8 tubing ---> quickly replaced with Primochill after I had bad plasticiser issues
Antec Earthwatts Green 650 Powersupply W/fan replaced with a Gentle Typhoon
Rosewill powered USB 3.0 hub
Logiteck MK 270 combo (I absolutely hate the mouse...will get changed soon)
Windows 8 Pro
Second PC/Server
Intel DG33tl
Q6700
8GB DDR2 Corsair
RX360 Radiator
3 Gentle Typhoon in Push config
Primochill 7/16 x 5/8 tubing (see above)
Rosewill Green Series Power Supply 430w W/ fan replaced with a Gentle Typhoon
1 TB Western Digital Caviar Blue
1 TB Western Digital Caviar Black
2 TB Seagate Barracuda XT
1.5 TB Seagate Barracuda
Logitech MK 550 (big keyboard but awesome mouse!!)
Windows 8 Pro
Shared Components
NZXT Sentry Mesh fan controller
4 Gentle Typhoon fans
FrozenQ Dual Chamber Reservoir
Monitor - 40" Samsung LCD UN40ES6100
Coolant
Distilled Water
Mayhems Blue
Mayhems UV CLear
Dead Water
Fittings/Misc Parts
Bitspower 7/16 x 5/8 Compression fittings
XSPC 7/16 x 5/8 Compression fittings
XSPC 90degree rotary fittings
AlphaCool 90degree adapters
Phobya 45degree rotary fitting
24gauge wire to extend fan wires
Mod/Smart Sleeved cable extensions
Bitfenix Sleeved Sata adapters
Logisys UV cathodes
The Desk
Pine
Silverstone Filtered Fan Grilles
Minwax Classic Black stain
screws (lol no seriously between 1/4" to 1 1/2")
small hinges
The first arrival
this is what was inside..
More Boxes
ooo look! fittings!
my Fedex/UPS people hate me I'm sure
TAP Plastics really ships their stuff well I must say
Getting a real life idea on placement (paper only gets me so far)
Now lets puts some stuff together
Now lets see how some of this fits (only had 1 rx360 so I had to move it around)
Fans and Fittings
Ok lets cut some stuff!!!! (still have all my fingers? check!)
Now to check the fit...Yay so far so good
What about the GPU? Yup that fits too
Top pieces cut and fitted
Lets see how she looks together
Finished Staining and test fitting the TAP Plastics Acrylic top
Putting together the loop and testing the cathodes
Slowly Coming together!!!!
hinged rear panels installed...
Leak/Glow/I got bored test (main Res not installed more on that in a sec)
What was to be the final piece
Oh not its leaking everywhere! Had to send it back for repairs or a replacement. Haven'tgotten it back yet...been about a month but it should be here within a couple days!!! Right now both loops are running without it (d5vario/res combo on both) you can see the XSPC tubing in the front too...gross
Installing OS, drivers and other necessary things..Windows 8 Pro, Plex, FileZilla etc
good thing I have a laptop otherwise I would have been without a computer for a few months...scary thought
As of right now I am waiting for the FrozenQ res to come back and my remaining Gentle Typhoons to come in to replace the XSPC fans on the rads...
This is The Desk 1.0, I already have plans for adjustments such as a cutout for my legs (I'm 6'2" so I'd like a weebit more clearance), might find a block for my 9800gt to throw on the server since its very laggy at 720p...not that I use it that much but just because. I probably will bite the bullet and order a glass panel to replace the acrylic top...it looks pretty but it scratches easily.
Thats it for now! 3rd year of law school started so free time doesn't come in large blocks anymore. Any and all criticism is welcome and suggestions too. Like I always say this is the interwebz and I'm a big boy now
Main PC
AMD FX-8350
8GB Gskill Ares
RX360 Radiator
Windows 8 Pro
Second PC/Server
Intel DG33tl
Q6700
8GB DDR2 Corsair
RX360 Radiator
Windows 8 Pro
Shared Components
Coolant
Distilled Water
Mayhems Blue
Mayhems UV CLear
Dead Water
Fittings/Misc Parts
Logisys UV cathodes
The Desk
Pine
small hinges
The first arrival
More Boxes
ooo look! fittings!
Fans and Fittings
