- Mar 24, 2003
- Dallas
Phenom ii beeping then resets on MSi K9A2 Platinum
I recently upgraded my system from a regular AM2 "Phenom 845 X3" to an AM3 "Phenom ii 955 BE X4". I'm using the same MB in my signature "MSI K9A2 Platinum w/ latest BIOS revision for AM3 support", and for whatever reason after overclocking my system from 3.2ghz to 4.2 ghz my system will start beeping and then just restart on it's own. I'm using a Corsair H50 water cooler w/ both waterblock and cpu chip lapped to a shine, and radiator is using 2 fans push/pull with 1 inch spacer to eliminate dead-space in center. I've upgraded my PSU from an antec 600 to a corsair 750TX, and the only components in my comp are my GPU (ATi HD3870 stock clocks), 1 PCI card "Killer NIC", 3 HDs (all Sata, 1 10,000rpm), and finally 1 Optical disc and several fans (3x120mm, 2 x 80mm, 1x 20mm, and the waterblock pump). Other then what I've already given you as far as my system is concerned, I can tell you it will run 4.0ghz @ v1.44 cpu fine, with all other system voltage stock. However once I bump it up to the 4.2 ghz @ v1.48 cpu, under full load it will start beeping then power off. I can't figure out why because the temps (according to coretemp) never exceed 45C, so what could be making this damn thing beep and shut off? The only odd thing is my power rails in
HWmonitor show
3.3v = 3.36
5.0v = 4.71
12.0v = 8.01
Anyone got a freaking clue why my comp is flipping out @ only 45C coretemp under 100% load when the threshold for thermal on these is suppose to be like 62C? I can't think of anything else but Temp that would cause this behavior. last but not least... according to SANDRA CPU power consumption @ 4.0GHZ is... 248Watt and @ 4.2GHZ is... 267Watt. It the 750TX just not enought juice? I find that hard to believe... HELP GUYS
HWmonitor show
3.3v = 3.36
5.0v = 4.71
12.0v = 8.01
