Hy,
I've searched a way to solve my particularly problem but no luck so far, hope to find a solution here.
This is my problem:
-I've unlocked my 555 in Phenom II X4 B55 with MOBO Asus M4a79 Deluxe
-all settings are on default in BIOS, I only activate the ACC, unleash mode options for unlocking
-the OS is Win 7 Pro 64 bit, is booting and I don't receive any BSOD
-I run the CPU & Memory stability tests immediately after unlocking (Prime 95, OCCT: CPU, S&M, Memtest86+...) no problem found, temps are in idle ~38 C and full load max 57 C
=>the problem appears when I start browsing, I receive pink, green stripes as the content is not well decoded on portion of the page displayed (this in Chrome or Firefox because Internet Explorer is not even starting..), I tried to increase the voltages of NB, CPU VID but there is no change.
I observed that after changing in Task Manager the "Set Affinity" to core 1,2,3 without core 0 the problem disappears, I also saw that in OCCT is failing ONLY the test for power supply (after 2-3 min). In S&M I observed also that tree cores (1,2,3) are at 100% when testing power supply but core 0 oscillate between 78% - 83%. In the core specific tests the load of core 0 reaches 100% without no problem.
Another problem I received was when I tried to instal my OS with CPU unlocked, the error received was that the hardware is not supported.
I read that the reason of locking the cores could be a faulty core... but this problem could be from my PSU (MS-Tech VERTIGO series 620 w 80+)? or from my ACC option or simply I'm not lucky?
Thank you!
This is my problem:
Thank you!
