What mobo would you recommend?
You have H100i, AiO cooler? Think I saw that earlier. That should be good to about 4.5Ghz if you get a decent piece of cpu silicon if the case and rads are well ventilated with good air-flow.
FYI, there is something up with availibility of the good AM3+ mobos. Like they are quitting them since AMD is not going to bring the "steamroller" FX processor and AMD seems h*ll bent for APUs. So what I am saying is that depending on what country you live in, there maybe an out of stock right now on some of the better boards.
With your W/cooling and knowing I just wrote in a thread that it seems not even overclocking an FX-8xxx if the speed reached is n0t 4.5Ghz, then my very first choice of mobo and that is with even my money >> Asus Sabertooth 990FX R2.0. Hands down a board that can handle the FX-8320 and give plenty of options and fun working "with" the mobo, instead of in spite of the mobo.
I think 'my' second choice (tied with my first) would be the Asrock FX990 EXT9 board. I have an earlier version and it is just about as handy and robust as my CHV non-Z board.
If and that is a huge "if" you knew for sure you could get a Rev 4.0 of a Gigabyte UD3 series or UD5 series and only Rev 4.0...then it might be a little cheaper on the pocket book. KNOW that most of us that are 'helpers' can setup and push an FX 8core on the Sabertooth 990FX R2.0 in our sleep. CHV-Z the same way. We have been there and done plenty of it. If you forge your own path with Giga or otherwise, we are not so used to what the heck is actually in the board bios. Would need very good pics to see all the settings. Doable but not a "known" at this time.
It is just a strange time in AM3+ mobo land. If you get a good one that can hold up, then I think you will be better off to begin with. If the any of the manufacturers cut production...the prices will jump and it seems a good year that AMD will still have for sale the FX series. You need a good board to hold-up that long and clocked.
RGone...
EDIT:
I must be dreaming. I thought I saw a post asking what AM3+ mobo might be suggested if you cancelled your order for the 970 EXT3 board. I put up what I personally would do but now I no longer see that request for a suggestion. Maybe you cannot cancel the 970 EXT3. I think you could refuse the order at the door and then haggle of refund and get something else. Oh well.
END EDIT.
