cameronmc88
- Sep 1, 2012
Hello all,
I've managed to reach a 3.8ghz stable with my CPU for 8-10 hours with Prime95 and no errors according to Prime95.
But it runs a little hot and would like some help please!
System Specs:
CPU: AMD Phenom II X4 955 (C2)
Ram: 4GB of DDR2 OCZ2RPR10662G
Motherboard: GA-MA780G-UD3H
Aftermarket Cooler: Zalman (Unsure what one sorry, lost the box ages ago, but least it's not the stock)
BIOS Settings:
Multiplier: 19x 200 (3.8ghz)
Ram: 1066mhz and EPP Voltage, Timings
HT Link: 2000
NB Freq: 2400
Core Voltage: 1.5v
CPU-NB Voltage: 1.25v
NB Voltage: Stock
SB Voltage: Stock
Anyway can someone help me figure out if these temps are safe or help me get them lower!! because I can't seem to get it stable without having Core Voltage at 1.5v which sucks because it runs hot, idle around 36-38c and when running prime I think the highest was 63c which I read is the limit or close to it.. and I've tried lowering the Core Voltage to 1.475v to maybe keep it cooler, no go it crashes in Prime95 after like 2 minutes or so.
Btw I have my NB Freq at 2400 because I read a guide somewhere saying 2400 is perfect for 3.8ghz CPU (Can anyone confirm if that is correct or would maybe 2600 or even 2800 would perform better?) with 1.25v for the CPU-NB Voltage from the same guide.
Note: It's the C2 stepping and I heard they are hotter? or don't overclock as well.
Thanks in advance!
System Specs:
BIOS Settings:
HT Link: 2000
NB Freq: 2400
Core Voltage: 1.5v
NB Voltage: Stock
SB Voltage: Stock
Thanks in advance!
