- Mar 23, 2012
I have just had a look on the giga website and I found you're problem with the vcore option! You're board does not support the proc that you ate using, don't panic! It doesn't mean it won't work, it just means that they don't have a bios revision to support that or any am3 chips, but I like the way you have managed to overcome you're vcore problem "very intuitive" if a pain on every start up
Hehe, I was aware of the AM3 issue when buying the Phenom II. It wasn't like that though back when I bought the board:
Check here to see what I mean:
http://club.myce.com/f7/gigabyte-ga-ma770-ds3-rev-1-0-supports-am3-cpu-306295/
I can live with lowering the Vcore from AMDOverdrive if I manage to keep the temps low - which I think I will soon.
Saving a few bucks now would cost us more later, as it's a nice cooler to keep for a new system in a couple of years huh? Ok challenge accepted, I will buy TWO FANS too (one for the side). Omg what a copy cat am I?Mitukczuk said:think the cooler is a really good choice for the price. Its getting pretty nice reviews.
Also, if you want to save few bucks, buy the non-EVO version CM Hyper 212+. They are almost identical except the fan. EVO cools a bit better though. As I said earlier, the cooler plus new case with big exhaust fan cooled my cpu by 12C+ during full load and with the addition of front intake fan and smaller intake fan on the side it allows me to overclock pretty nice while still being under 50C. (Gotta stick to a minimal OC though as my mobo needs upgrade)
