skull rebell
- Jul 26, 2014
Hello All, I'm new to overclockers and plan on upgrading my current system to Liquid Cooling so i can get better performance, currently i'm running a
I5. haswell 4670k
1tb WD Black hdd
2x8gb Corsair Vengence DDR3 1600
Asus GTX780 Direct 2 CUoc
2 kingston 60gb SSD
Asus CD/dvd drive
sunbeam pl-rs-6 fan controller optical drive bay
Asus Xonar Ds
seasonic g-750 ssr 750rm
Corsair H80i
Asrock z87 Pro3
I Am thinking of running 1 120mm rad and a 240mm rad , cpu block, dual 5.25'' drive pump res combo, and gpu block I just have no idea on rez thickness that would appropriate for my case as I'm building in a Cooler-master, HAF Evo XB, I also plan on removing the drive bay and swapping the fan controller for some molex connector adapters.
I plan on using compression fittings or quick release fittings, If i could get some product recommendations, tips, and Ideally i want to run the coolant, close to Nvidia green or use dark green tubing.
Thank you and cant wait to learn more here on overclockers
I5. haswell 4670k
1tb WD Black hdd
2 kingston 60gb SSD
Asus CD/dvd drive
Asus Xonar Ds
Corsair H80i
Asrock z87 Pro3
