Would Like comments / suggestions on improving this build, and if anything in the configuration is a bottleneck, or extreme overkill when added to the rest of the components.
Would Like to run it stock for a while, but be able to overclock a little later .
CPU: Q9450
Motherboard: DFI LANPARTY DK X48-T2RS
http://www.newegg.com/product/product.aspx?item=N82E16813136047
RAM: G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1000 (PC2 8000)
http://www.newegg.com/product/product.aspx?item=N82E16820231145
Video 1: EVGA 01G-P3-N897-AR GeForce 9800 GX2 SSC 1GB 512-bit GDDR3 PCI Express 2.0 x16 HDCP
http://www.newegg.com/product/product.aspx?item=N82E16814130344
Video 2: EVGA 256-P2-N758-TR GeForce 8600GT SCC 256MB 128-bit GDDR3 PCI Express x16 SLI
http://www.newegg.com/product/product.aspx?item=N82E16814130311
(This Card is just so I can run extra displays in 2D - Not trying to SLI)
PSU: Antec TPQ-850 ATX12V / EPS12V 850W Power Supply 100
http://www.newegg.com/product/product.aspx?item=N82E16817371009
HDD: Seagate Barracuda 7200.11 ST3500320AS 500GB 7200 RPM 32MB Cache SATA 3.0Gb/s Hard Drive
http://www.newegg.com/product/product.aspx?item=N82E16822148288
Times 2x for raid
The 2 things im most unsure about are the ram and PSU
1 - Is that an OK ram for running 1:1 with the FSB at 4x400, but still leaving a little room to OC later?
2 - Is the PSU overkill for the system?
Thanks !
Mike
CPU: Q9450
Times 2x for raid
Thanks !
Mike
