Hi,
This is my 1st ever attempt to try my hands at some Over Clocking.
The forum has some great information. I did go through the following guides, but must admit, I’m struggling a bit.
The threads I read, and it was very helpful:
A8N32-SLI Deluxe settings: http://www.ocforums.com/showthread.php?t=468038
Easy as 1, 2, 3, Overclocking the A64, Optron, X2. : http://www.ocforums.com/showthread.php?t=391768
What I have done thus far:
AMD Cool 'N Quiet Configuration [Disable] CnQ.
Onboard Devices: [Disable] all the Onboard Devices not being used.
USB Configuration: [Disable] Legacy USB.
JumperFree Settings:
[/URL][/IMG]
Chipset:
[/URL][/IMG]
How do I proceed from here?
My Memory Specs:
http://www.ocztechnology.com/products/memory/ocz_el_ddr_pc_3200_dual_channel_platinum
CPU_z attached and below.
CPU-Z 1.44.2 report file
Processor(s)
Number of processors 1
Number of cores 2 per processor
Number of threads 2 per processor
Name AMD Athlon 64 FX-60
Code Name Toledo
Specification AMD Athlon(tm) 64 FX-60 Dual Core Processor
Package Socket 939
Family/Model/Stepping F.3.2
Extended Family/Model F.23
Brand ID 6
Core Stepping JH-E6
Technology 90 nm
Core Speed 2608.1 MHz
Multiplier x Bus speed 13.0 x 200.6 MHz
HT Link speed 1003.1 MHz
Stock frequency 5000 MHz
Instruction sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64
L1 Data cache (per processor) 2 x 64 KBytes, 2-way set associative, 64-byte line size
L1 Instruction cache (per processor) 2 x 64 KBytes, 2-way set associative, 64-byte line size
L2 cache (per processor) 2 x 1024 KBytes, 16-way set associative, 64-byte line size
Chipset & Memory
Northbridge NVIDIA SPP100 (C51D) rev. A2
Southbridge NVIDIA nForce4 MCP rev. A4
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR
Memory Size 4096 MBytes
Memory Frequency 200.6 MHz (CPU/13)
CAS# Latency (tCL) 2.0 clocks
RAS# to CAS# (tRCD) 3 clocks
RAS# Precharge (tRP) 2 clocks
Cycle Time (tRAS) 5 clocks
Bank Cycle Time (tRC) 11 clocks
DRAM Idle Timer 16 clocks
Command Rate (CR) 2T
System
System Manufacturer System manufacturer
System Name System Product Name
System S/N System Serial Number
Mainboard Vendor ASUSTeK Computer INC.
Mainboard Model A8N32-SLI-Deluxe
BIOS Vendor American Megatrends Inc.
BIOS Version 1405
BIOS Date 01/08/2007
Memory SPD
Module 1 DDR, PC3200 (200 MHz), 1024 MBytes, OCZ
Module 2 DDR, PC3200 (200 MHz), 1024 MBytes, OCZ
Module 3 DDR, PC3200 (200 MHz), 1024 MBytes, OCZ
Module 4 DDR, PC3200 (200 MHz), 1024 MBytes, OCZ
Software
Windows Version Microsoft Windows XP Professional Service Pack 2 (Build 2600)
DirectX Version 9.0c
Chipset:
My Memory Specs:
Processor(s)
Code Name Toledo
Package Socket 939
Brand ID 6
Core Stepping JH-E6
Technology 90 nm
Chipset & Memory
Memory Type DDR
System
BIOS Version 1405
Memory SPD
Software
