OK, what's this thread about? Other then alot of rambling, it seems sorta like people are debating which is better, pushing air in, or drawing air out of a case. From any practical aspects I can imagine, where any heat is being generated, better to exhaust that heat out as close to the source as possible. Any place else, it would be better to inlet air. I would also surmise the cfm going into the case, would help augment the discharge of component heated air leaving the case. How could any other way then this be advantageous?
As a contractor, I can tell you added air volume in one enclosed space, will move that excess volume into adjoining space, or any open space it can find. I can also tell you that cold air is more dense and heavier then hot, which would cause a potential for more air to come into the case at a lower level as the warmer air within the case would tend to leave the case at a higher level. For this reason, moving heat away and out of the case, would by necessity, bring cooler air into the case, given there is a colder potential difference between the heat source and ambient air outside the case. It would further mean that fans would work better drawing or pushing air into the case at a lower point, and fans drawing or pushing air out of the case should be at a higher point. This would have a higher potential for better cooling the case interior then if reversed.
Therefore, it is always wise to have more fan power pushing/pulling air in the case and at a lower point, then pushing/pulling air out of the case and at a higher point. And regardless of how leaky any case is, when more volume of air is induced into that case, there will absolutely be a pressure differential with a higher pressure in the case the outside the case. Like the poster earlier with the water idea, you could also say water always runs downhill, unless and added volume of water is induced and forces it up and over obstacles it finds in its path. In physics, all matter seeks to stabilize itself with all surrounding matter. Working with it, is easier then working against it.
