So we have concluded there is no case pressure. And without pressure differentials, there is no air flow. I think I will look for physics refreshers elsewhere.
Nothing wrong with arguing no difference in cooling between negative and positive air pressure, or downplaying differential differences. But no need to go overboard and butcher physics.
Here is quote from one basic reference on Bernouilli principle, in this case an HVAC system, but any high school physics book will do:
Flow of air or any other fluid is caused by a pressure differential between two points. Flow will originate from an area of high energy, or pressure, and proceed to area(s) of lower energy or pressure. Conservation of mass simply states that an air mass is neither created nor destroyed. From this principle it follows that the amount of air mass coming into a junction in a ductwork system is equal to the amount of air mass leaving the junction, or the sum of air masses at each junction is equal to zero. In most cases the air in a duct is assumed to be incompressible, an assumption that overlooks the change of air density that occurs as a result of pressure loss and flow in the ductwork. In ductwork, the law of conservation of mass means a duct size can be recalculated for a new air velocity using the simple equation:
V2 = (V1 * A1)/A2
Where V is velocity and A is Area
The law of energy conservation states that energy cannot disappear; it is only converted from one form to another. This is the basis of one of the main expression of aerodynamics, the Bernoulli equation. Bernoulli's equation in its simple form shows that, for an elemental flow stream, the difference in total pressures between any two points in a duct is equal to the pressure loss between these points, or:
(Pressure loss)1-2 = (Total pressure)1 - (Total pressure)2
Conservation of momentum is based on Newton's law that a body will maintain its state of rest or uniform motion unless compelled by another force to change that state. This law is useful to explain flow behavior in a duct system's fitting.
And yes the case pressure is small in our computers, since scale of system case and fans are small and have little kinetic energy/static pressure, typical being 2-5mm h20. But really no different than using a box fan in a window of a 3500 sq foot house and doing a blower door test, scale is larger, fan is larger, but still setting up a relatively very small but effective enough to measure pressure differential.
And while I dont think it matters neg or pos pressure for cooling, this pressure can have effect on liquid cooling as has been indirectly measured by many with accurate equipment. Try blowing air through 2 360 rads, all expelling air into a case with only 1 fan expelling air. The air resistance from CASE PRESSURE, causes a 30% loss in cooling. Drop side panels, and delta air to water temps drop dramatically as the air moving through rad dramatically increases...not to mention the blowback of air over rad fans decreases.
So does discussing neg or pos air pressure help for air cooling, doubt it. Does it exist, it does if air flow exists.
