- Jan 28, 2012
I7 950 overclock question
Hello all. Small OC question. I havent BSOD in a while but I just did. I checked my event view and this was my error.
Fault bucket X64_0x124_GenuineIntel__UNKNOWN_PRV, type 0
I assume it is telling me I am missing something with my OC.
MOTHERBOAD = Asus Rampage II Extreme
CPU = I7 950 3.06 Quad Bloomfield currently at 4.0
RAM = 8GB G Skill ripjaw series DDR3 1600MHZ 9,9,9,24 2N
GPU = EVGA GTX580 FTW ( SLI )
PSU = 1200W Thermaltake toughpower
TARGET PU FREQUENCY: 4000MHZ
TARGET DRAM FREQUENCY: 1603MHZ
AI OVERCLOCK TUNER = XMP
OC FROM CPU LEVEL UP = AUTO
OC FROM MEMORY LEVEL UP = PROFILE 1
CPU RATIO SETTING = 20
CPU TURBO POWER LIMIT = ENABLED
BCLK FREQUENCY = 200
PCIE FREQUENCY = 100
DRAM FREQUENCY = DDR3 - 1603MHZ
UCLK FREQUENCY = AUTO
QPI LINK DATA RATE = AUTO
DRAM TIMING CONTROL = 9,9,9,24 2N ( MANUALLY ENTERED )
EPU II PHSE CONTROL = FULL PAHASE
LOAD LINE CALIBRATION = AUTO
CPU DIFFERENTIAL AMPLITUDE = AUTO
EXTREME OV = DISABLED
CPU VOLTAGE CONTROL = ABSOLUTE VID
CPU VOLTAGE = 1.30
CPU PLL VOLTAGE = AUTO
QPI/DRAM CORE VOLTAGE = 1.30
IOH VOLTAGE = AUTO
IOH PCIE VOLTAGE = AUTO
ICH VOLTAGE = AUTO
ICH PCIE VOLTAGE = AUTO
DRAM BUS VOLTAGE = 1.5 ( MANUALLY ENTERED )
DEBUG MODE = STRING
KEYBOARD TWEAKIT CONTROL = DISABLED
CPU SPREAD SPECTRUM = DISABLED
PCIE SPREAD SPECTRUM = DISABLED
CPU CLOCK SKEW = AUTO
IOH CLOCK SKEW = AUTO
These are the settings in the CPU CONFIGURATION MENU
CIE SUPPORT = DISBLED
HARDWARE PREFETCHER = ENABLED
ADJACENT CACHE LINE PREFETCH = ENABLED
INTEL(R) VIRTUALIZATION TECH = ENABLED
CPU TM FUNCTION = DISABLED
EXECUTE DISABLE BIT = ENABLED
INTEL(R) HT TECHNOLOGY = ENABLED
ACTIVE PROCESSOR CORES = ALL
A20M = DISABLED
INTEL(R) SPEEDSTEP(TM) TECH = DISABLED
INTEL(R) C-STATE TECH = DISABLED
There you have it. I would assume my CPU is more capable of 4.0 but I want to make sure I give it all it needs so I either don't kill it, or incap it and don't give it enough. I think it might have been the CPU voltage but I may be wrong. Any help is appreciated
CPU VOLTAGE = 1.30
IOH VOLTAGE = AUTO
ICH VOLTAGE = AUTO
DEBUG MODE = STRING
A20M = DISABLED
