Hi Strike! Welcome to the OC Community!
I know a surge protector won't help because it's already fried several parts, cause it's not a full blown surge.
Could you elaborate on what happened? If you're currently using a surge suppressor, and have had failed components if your computer, but not anywhere else in your house (DVD player, TV, microwave, etc) then you may have a faulty/failing PSU.
The wiring in my house is quite old and I need some way to correct the voltage
How old? Do you know if your wiring is grounded? (Mine isn't). I ask, because you can buy the best MOV based surge suppressor, but without a ground it's offering very little protection. (Most surge suppressors use Metal Oxide Varistors (MOV) for protection, as they are cheap to make and mass produce.)
Let me elaborate. There are three 'modes' that a MOV-based surge protector uses when encountering a surge: normal mode, which is hot to neutral (H-N) and two common modes neutral to
ground and hot to
ground (N-G / H-G). If your house wiring really is that old, and there is no ground, then no matter how expensive the MOV protector is, it's only protecting you from 1/3 of the surge types: H-N surges.
Any-who, all that to say, that if there is no ground then you'll need something different. The link BrianAbington referenced may have some, but do your research...if the products are MOV based (or, for example, have a "response time" or "joule rating") then move on to something else.
For the bad news: Adequate protection is expensive. I know, because the house I'm in is quite old, and actually doesn't have ground wiring. (And as you can tell, I had to do lots of research to find out how to protect my equipment).
Here is what I ended up with. It's from a company called SurgeX, and they are awesome.
They are not MOV based, do not have "response times" (technically it's 0ns response time) and are not limited by a certain "joule rating". It's called "Series Mode" surge elimination;
more info here. Once I got this puppy installed, all of my flaky/weird power related system issues went away. Hell, even my broadband connection stopped dropping. (Did I mention I hate crappy old house wiring??) Sure, it's pricey (~$350) but how much would it cost to keep replacing computer parts instead?
DISCLAIMER: I am in no way affiliated with, own stock in, or otherwise have a vested interest in SurgeX. I'm just a really, really, really, really happy customer after all the problems it solved for my power filtering woes. Hell, the guy I was emailing with questions for, like, a week at their HQ actually
sent me a post card.
