- Mar 1, 2013
The only PSUs I have seen that use Cindy Wu technology (basically a digital inverter for the fan motor) are some ultra high power density rackmount units. Even the 1kW+ ATX units don't run hot enough to require extremely good cooling since power stuff is somewhat more forgiving of high temperatures than delicate logic.It's the Cindy Wu circuit, I heard that on the Internets.
The PFC circuit is the only part of the PSU that deals with the 50/60Hz input. If the power line frequency is 60Hz and the video output is also 60Hz or a multiple (but not exactly), it's possible to get a buzz that cyclically comes and goes. As a test, try setting the refresh rate to something else and see if the noise changes.
If you suspect some high frequency ripple from a voltage regulator getting back to the PSU and causing interactions, you can try adding some clip on ferrites to the cables. Put it around the yellow wires coming off a PCIe or CPU power connector.
