so does tis mean I am getting my full 350 watts from my psu or am I getting a lower wattage.. I found this on antec website which is the specs on the psu supply that came with my case and has me wondering. It says down below about different watt supplys with and without the 12 volt rail connector...and also is there a way I can check and see what my actuall wattage out put is from my supply a safe way that is...lol.. thanks guys..
Model: SL350 / SmartBlue350
FEATURES
Maximum Power
350W
Transient Response
+5V,+12V outputs return to within 5% in less than 1ms for 20% load change.
P. G. Signal
100-500ms
Over Voltage Protection
recycle AC to reset
+5V trip point < +6.5V
+3.3V trip point < +4.1V
+12V trip point < +15.6
Overload Protection
Latching Protection
+5V @ < 50A
+3.3V @ < 48A
+12V @ < 21A
Leakage Current
<3.5mA @ 240VAC
OUTPUT
+5V
-5V
+12V
-12V
+3.3V
+5V
SB
Max. Load
35A*
0.5A
16A
0.8A
28A*
2.0A
Min. Load
1.5A
0A
0.8A
0A
0.5A
0A
Load Reg.
± 5%
± 10%
± 5%
± 10%
± 5%
± 5%
Rippe
V(p-p)
50mV
100mV
120mV
120mV
50mV
50mV
this area here is what has me concerned...
* +5V and +3.3V combined output: 230Watts max.
* +5V, +3.3V and +12V combined output: 330Watts max
ENVIRONMENTAL
Operating Temp.
10 ºC to 50 ºC
Operating Alt.
Sea Level-10,000 ft
Non-Operating
Vibration
Operating: 10-300 Hz, 0.5G, 3 axes, 1hr ea. axis
Non-operating: 10-300 Hz, 2.0G, 3 axes, 1hr. ea axis
MTBF
50,000 hrs. @ 25ºC
Weight
5 lbs.
Approvals UL, TUV, CB, FCC CLASS B, NEMKO
