with the use of crystalcpuid http://crystalmark.info/download.html
set clock management settings, then enable it. mine fluxes from 2.2ghz to 400mhz. drops the cpu temp by no small amount, and thats even with my voltage locked because i have a lousy ecs m/b that can't pull that stunt. so stuck at 1.85v
probably not as good as the opteron solution ..but might as well use this mobile feature no?
without it, i run 44c~ with it, 35c~ web surfing... 31c~ more or less idle.
this seems to be the only software solution right? amd had some powernow! software on their site, but it was only for non windows xp oddly enough.
