- Apr 29, 2001
I've been tweaking my new system (Gigabyte GA-Z68A-D3H-B3), and applied a new cooling fan (Arctic Freezer XTREME Rev2). Corsair Vengeance (4x4GB)
I found that, with XMP enabled for RAM, the CPU vCore then goes up to 1.35v in the BIOS. With XMP disabled and the RAM frequency set to 1600 manually, the vCore (BIOS) stays at 1.23v - where I want it.
In Windows, idle, the CPU draws 0.97v and runs at 1.6GHz. Under slight load this goes up to 3.4GHz and draws 1.28~1.3v. But with Prime95 running - the voltage goes up to 1.36v (the CPU reading 3.8GHz for Turbo mode, all 4 cores).
Idle temp is 29C. Full load temp gets to 64C, which is great but the amount of voltage drawn suggests - if it can be lowered and the system remains stable - that the load temp would go down as well.
LLC is set to "auto".
Changing LLC to "disabled" using the overclocking app in Windows had no effect, but I suspect I'd have to reboot to confirm the settings...
CPU Overcurrent protection is enabled...
Real time changes in OS is disabled, so I'm definitely confused as to why it's changing the voltage requirement...
Should the voltage spike up to 1.36v under load? I know that particular voltage is needed when overclocking to 4.5GHz or higher, but for the moment I need to establish a baseline using the CPU's own defaults (1.2v, 3.4GHz normal, 3.8GHz turbo).
CPU PLL remains at "auto", but I'm not sure that's relevant.
What other settings will reduce the amount of voltage applied to the CPU under heavy load? That will help run the system cooler as well as allowing greater overclocking, under voltages I know won't damage the CPU (1.38v is the max).
Thanks much!
Thanks much!
