- May 17, 2005
- High Desert, Calif.
I just set up Win 7 Pro(64bit) about four days ago, was a bit surprised to get a BSOD a few minutes after booting. Rebooted, then got another bluescreen- now I'm paying attention. I figured that a recent Update may have been the cause, so I rolled System Restore back to before Updates. Another bluescreen. I'm getting the following:
Googling
...so ATM the machine is automatically trying to fix file system errors and scan for and attempt recovery of bad sectors.
Does this actually sound like 'disk corruption' or some such problem, or is there something more tangible going on?
Edit:
My purpose for this Win7 setup is to attempt to run a scanner(this post) that has drivers & software compatible up to Win XP only.
Other actions:
Dropped this skt 1155 i7 2600K back to stock clocks, ran OCCT Large Data Set for one hour, also ran Linpack for an hour; no anomalies detected. Currently has been running a f@h WU smoothly.
Code:
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.1.7600.2.0.0.256.48
Locale ID: 1033
Additional information about the problem:
BCCode: 24
BCP1: 00000000001904FB
BCP2: FFFFF880038FF408
BCP3: FFFFF880038FEC70
BCP4: FFFFF80002AF79E1
OS Version: 6_1_7600
Service Pack: 0_0
Product: 256_1
Files that help describe the problem:
C:\Windows\Minidump\061513-20248-01.dmp
C:\Users\tnthomas\AppData\Local\Temp\WER-34601-0.sysdata.xml
Googling
led to answers.microsoft.com where it was stated that:BCP1: 00000000001904FB
The Blue screen of Death error (BSOD) description you have posted indicates Bug Check Code 24 (BCCode: 24) that is caused by a problem in Ntfs.sys
Usually it is caused by disk corruption, disk defragmenters, or (in rare cases) creating a partition larger than 7 GB on a Services for Macintosh volume with a large number of files. The general troubleshooting steps to solve this issue if it occurs randomly are suggested below.
Method 1: - Check drive for errors
1. Open Computer by clicking the Start button, and then clicking Computer.
2. Right-click the drive that you want to check, and then click Properties.
3. Click the Tools tab, and then, under Error-checking, click Check now. If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
To automatically repair problems with files and folders that the scan detects, select Automatically fix file system errors. Otherwise, the disk check will report problems but not fix them.
To perform a thorough check, select Scan for and attempt recovery of bad sectors. This scan attempts to find and repair physical errors on the drive itself, and it can take much longer to complete.
To check for both file errors and physical errors, select both Automatically fix file system errors and Scan for and attempt recovery of bad sectors.
Edit:
Other actions:
