Hey guys, I'm not new to the site I enjoy reading the many articles here and late last year Built my very own liquid cooled system late last year but I've recently run into a problem.
So it had been about 5months since I last touched her and I decided it would be a good idea to replace the water (using straight distilled with some pt and a small chunk of pure silver).
Drained it, refilled it (not seeing any real damage to the tubing)
I've got next to no flow rate.
Drained it again, disassembled made sure I didn't miss anything and got some better cleaning done to some neglected spots.
Refilled and same issue.
My first assumption was maybe the pump fried somehow(it made the most sense to me) ordered a new pump replaced the old one and still no flow. At this point I'm running out of ideas and think maybe there is something blocking on the inside of my rad enough to mess my flow right up but not enough to stop me from fully bleeding the line.
I pulled the rad + pump + res out and looped them outside the box and there is a strange almost metallic gurgle but the flow is good. I "think" I've found my culprit but before I order a new very expensive rad I was hoping someone might have a confirmation/other idea of my problem.
Here are my specs:
CPU: EK supreme HF -Copper/Acetal
GPU: EK-FC480 GTX -Nickel/Acetal + black backplate
Reservoir: EK-BAY Spin 5.25" Bay Reservoir w/ Flow Meter -Acetal
Tubing: Feser Tube red and Tygon clear - 1/2" ID - 3/4" OD
Pump: Swiftech MCP655/speed control with a EK-D5 X-Top v2
Fittings: 9 x Bitspower G1/4" Matte Black High Flow 1/2"
Radiator: Black Ice GTX 360 Radiator
the replacement pump is a pmp 450s
older pic but the loop itself is in the same position/order and i've only fix cables/that clear tube
I'm a computer tech student and in the middle of my exams / case studies and having my main computer down is seriously hampering my ability to study / simulate stuff. (plus she is my baby I can't help but want to spend countless hours trying to save her)
oh should I run both pumps with a very short loop in hope that w/e is stuck in it gets rocketed out? (if there even is something)
Here are my specs:
