Problem with a EVGA NF41 and opteron 165 939 system
Tomsawyer
Afternoon all. Ok I have an ancient back up system that I allow my kids to use. In its prime under phase cooling and finally air it was a decent rig.
2 days ago it shut down and I ran through the process of removing components to finally I reached just the motherboard, power supply and cpu. The system will boot for about 1 second then power down. I have removed the CPU and heatsink (its an after market, huge copper base, cooling fins, fan, i think nocturna) and cleaned it, put new artic and made sure it was tight again.
The power supply is a PC n Power 550 and it tests out fine with the power tester.
I have removed the board and tested it on a static neutral bench I use.
Here is the crux: IF I run the system with the 4 prong power to cpu plugged into the motherboard it will only boot for a second or 2 before shutting down. IF however I remove that 4 prong power to cpu then the board and attached "case fans" will spin up, the board reports FF and it will just hum right along.
For the experts does this mean the CPU is bad? Or is it the motherboard?
I know its ancient, it needs to be upgraded but for my own education I was curious to know what others think. I myself upgraded last year to a sandybridge i2500k so if I take the plunge again I will get an ivybridge and move my sandy n board down to the kids. Have to buy more memory and other goodies but such is life :)
Add a reply Add to the list of quoted messages Quick edit Edit this message
Plugging and unplugging the 4 pin cpu power input and getting your symptoms has about a 75% chance of the cpu being bad.
I'd guess one of the CPU mosfets on the motherboard burned/shorted out.
