Ok got it running for now. Now the questions is why does the cpu heatsink/fan come on then go off? I think according to the manual, it would be that it comes on when the cpu temp gets to a point that you can set manually in bios.. Now I have never seen this type of setting in my ASUS boards, but I know this is a whole different animal.. When this first happened I figured my original fan was dying out, so I went and purchased a new one.. This one does the same thing, and that is when I found out that little info in the manual.. I have a fan that you can set the speed, so right now I have it set to slow and the fan stay running all the time.. If I speed it up it stops, and only kicks on when the temp get higher then what I have set in the bios, I hope I right what do you all think.
I'm using all my original hardware listed in my sig other than the ASUS board naturally.. Thanks again, and do not mine the rambling, just got out of work and I'm tired..
