Hello ocforums! Please take a moment to help me with an annoying graphics issue. I would greatly appreciate it.
Background: I built my computer around two years ago and this problem started happening maybe a year after the build. I just did a reformat yesterday and the problem persists, maybe it's a hardware problem after all?
Problem: When I load up a game in full screen mode (Counter Strike, America's Army, Battlefield 2...) everything is normal for the first few minutes of play. After about 30 minutes or so, my screen turns into this:
When I try to alt + tab out of the game my desktop screen looks like this:
The only way to get back to normal is to get into the game and alt + f4 (or sometimes I just use the game's console to type quit and that works too). Then I come to my normal desktop screen.
->I think this problem may have started happening after I got two new sticks of corsair ram and installed them to make my ram 2 GB instead of only 1 GB. Maybe the ram is corrupt?
->Also, this ONLY happens when the game is in full screen mode. It has never happened in windowed mode. Does that make any sense??
dxdiag:
Any input would be greatly appreciated as I'm totally stumped. Thanks guys!
dxdiag:
Code:
System Information
Time of this report: 8/16/2008, 23:45:20
Machine name: GAMER
Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 3 (2600.xpsp.080413-2111)
Language: English (Regional Setting: English)
System Manufacturer: System manufacturer
System Model: System Product Name
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: AMD Athlon(tm) 64 X2 Dual Core Processor 4200+, MMX, 3DNow (2 CPUs), ~2.2GHz
Memory: 2046MB RAM
Page File: 529MB used, 3409MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.5512 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: The file ctaud2k.sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce 7900 GT/GTO
Manufacturer: NVIDIA
Chip type: GeForce 7900 GT/GTO
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0291&SUBSYS_C5833842&REV_A1
Display Memory: 256.0 MB
Current Mode: 1680 x 1050 (32 bit) (60Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: nv4_disp.dll
Driver Version: 6.14.0011.7519 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 5/16/2008 14:01:00, 6108928 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 5/16/2008 14:01:00, 6557408 bytes
Device Identifier: {D7B71E3E-41D1-11CF-AD46-88E500C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0291
SubSys ID: 0xC5833842
Revision ID: 0x00A1
Revision ID: 0x00A1
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D ModeWMV9_B ModeWMV9_A
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: SB X-Fi Audio [9C00]
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_1102&DEV_0005&SUBSYS_00211102&REV_00
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: ctaud2k.sys
Driver Version: 6.00.0001.1284 (English)
WHQL Logo'd: No
Date and Size: 7/15/2008 18:07:18, 527384 bytes
Other Files:
Driver Provider: Creative
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 1, 192000
Static/Strm HW Mix Bufs: 128, 128
Static/Strm HW 3D Bufs: 128, 128
HW Memory: 0
Voice Management: Yes
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xFFF
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: Enabled
Ports: SB X-Fi DMusic Synth [9C00], Hardware (Kernel Mode), Output, DLS, Internal, Default Port
SB X-Fi Audio [9C00], Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB X-Fi Synth B [9C00] [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB X-Fi Synth A [9C00] [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: Saitek Eclipse Keyboard
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x06A3, 0x8020
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x10DE, 0x036C
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 4/14/2008 00:15:38, 59520 bytes
| Driver: usbd.sys, 8/4/2004 08:00:00, 4736 bytes
+-+ USB Human Interface Device
| | Vendor/Product ID: 0x046D, 0xC01E
| | Matching Device ID: usb\class_03&subclass_01
| | Service: HidUsb
| | Driver: hidusb.sys, 4/14/2008 00:15:28, 10368 bytes
| | Driver: hidclass.sys, 4/14/2008 00:15:28, 36864 bytes
| | Driver: hidparse.sys, 4/14/2008 00:15:24, 24960 bytes
| | Driver: hid.dll, 4/14/2008 05:41:56, 20992 bytes
| +-+ HID-compliant mouse
| | | Matching Device ID: hid_device_system_mouse
| | | Service: mouhid
| | | Driver: mouclass.sys, 4/14/2008 00:09:48, 23040 bytes
| | | Driver: mouhid.sys, 8/4/2004 08:00:00, 12160 bytes
Gameport Devices
PS/2 Devices
+ HID Keyboard Device
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| Driver: kbdhid.sys, 4/14/2008 00:09:50, 14592 bytes
| Driver: kbdclass.sys, 4/14/2008 00:09:48, 24576 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 4/14/2008 05:43:22, 40840 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 TCP/IP Service Provider: Local Area Connection 2 - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 95.7 GB
Total Space: 152.6 GB
File System: NTFS
Model: WDC WD1600JS-22NCB1
Drive: D:
Free Space: 370.5 GB
Total Space: 476.8 GB
File System: FAT32
Model: WD 5000AAV External USB Device
Drive: E:
Model: _NEC DVD_RW ND-3550A
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.5512 (English), 4/14/2008 00:10:48, 62976 bytes
System Devices
Name: Standard Dual Channel PCI IDE Controller
Device ID: PCI\VEN_197B&DEV_2363&SUBSYS_81E41043&REV_02\4&FC29FAF&0&0070
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.5512 (English), 4/14/2008 00:10:30, 24960 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.5512 (English), 4/14/2008 00:10:32, 96512 bytes
Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (English), 8/4/2004 08:00:00, 3328 bytes
Name: Creative SB X-Fi
Device ID: PCI\VEN_1102&DEV_0005&SUBSYS_00211102&REV_00\4&2BE4B97F&0&3830
Driver: C:\WINDOWS\system32\ksuser.dll, 5.03.2600.5512 (English), 4/14/2008 05:41:58, 4096 bytes
Driver: C:\WINDOWS\system32\ksproxy.ax, 5.03.2600.5512 (English), 4/14/2008 05:42:44, 129536 bytes
Driver: C:\WINDOWS\system32\drivers\ks.sys, 5.03.2600.5512 (English), 4/14/2008 00:46:38, 141056 bytes
Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.5512 (English), 4/14/2008 00:15:16, 60160 bytes
Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.5512 (English), 4/14/2008 00:49:42, 146048 bytes
Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.2600.5512 (English), 4/14/2008 00:15:16, 49408 bytes
Driver: C:\WINDOWS\system32\wdmaud.drv, 5.01.2600.5512 (English), 4/14/2008 05:42:46, 23552 bytes
Driver: C:\WINDOWS\system32\drivers\ctac32k.sys, 6.00.0001.1361 (English), 7/15/2008 18:06:46, 511000 bytes
Driver: C:\WINDOWS\system32\drivers\ctaud2k.sys, 6.00.0001.1284 (English), 7/15/2008 18:07:18, 527384 bytes
Driver: C:\WINDOWS\system32\drivers\ctoss2k.sys, 6.00.0001.1284 (English), 7/15/2008 18:08:36, 127000 bytes
Driver: C:\WINDOWS\system32\drivers\ctprxy2k.sys, 6.00.0001.1284 (English), 7/15/2008 18:09:44, 14360 bytes
Driver: C:\WINDOWS\system32\drivers\ctsfm2k.sys, 6.00.0001.1284 (English), 7/15/2008 18:10:28, 157208 bytes
Driver: C:\WINDOWS\system32\drivers\emupia2k.sys, 6.00.0001.1284 (English), 7/15/2008 18:11:14, 92696 bytes
Driver: C:\WINDOWS\system32\drivers\ha20x2k.sys, 6.00.0001.1284 (English), 7/15/2008 18:12:38, 1173016 bytes
Driver: C:\WINDOWS\system32\drivers\pfmodnt.sys, 3.00.0000.0012 (English), 7/15/2008 18:13:08, 15896 bytes
Driver: C:\WINDOWS\system32\ctdlang.dat, 7/11/2008 15:40:54, 321512 bytes
Driver: C:\WINDOWS\system32\ctdnlstr.dat, 7/11/2008 15:40:54, 56509 bytes
Driver: C:\WINDOWS\system32\CtxfiRes.dll, 6.00.0001.1283 (English), 7/11/2008 15:50:28, 3072 bytes
Driver: C:\WINDOWS\system32\ctzapxx.ini, 7/11/2008 16:22:30, 54 bytes
Driver: C:\WINDOWS\system32\instwdm.ini, 7/15/2008 16:35:42, 30305 bytes
Driver: C:\WINDOWS\system32\kill.ini, 10/2/2006 17:25:18, 307 bytes
Driver: C:\WINDOWS\system32\CT1MGM.ROM, 2/25/2000 12:49:36, 1048576 bytes
Driver: C:\WINDOWS\system32\CT2MGM.SF2, 9/22/1999 23:18:38, 2167684 bytes
Driver: C:\WINDOWS\system32\default4.sfm, 1/3/2002 15:44:16, 59 bytes
Driver: C:\WINDOWS\system32\default8.sfm, 1/3/2002 15:44:16, 59 bytes
Driver: C:\WINDOWS\system32\default.sfm, 1/3/2002 15:44:16, 59 bytes
Driver: C:\WINDOWS\Temp\ctpxst32.exe, 1.01.0000.0059 (English), 3/13/2007 10:32:14, 89336 bytes
Driver: C:\WINDOWS\Temp\cttele32.dll, 1.00.0005.0000 (English), 2/26/2007 15:24:00, 94208 bytes
Driver: C:\WINDOWS\system32\CTEXFIFX.DLL, 6.00.0001.1284 (English), 7/15/2008 17:22:46, 1323544 bytes
Driver: C:\WINDOWS\system32\CT20XUT.DLL, 6.00.0001.1284 (English), 7/15/2008 17:23:22, 170520 bytes
Driver: C:\WINDOWS\system32\CTHWIUT.DLL, 6.00.0001.1284 (English), 7/15/2008 17:23:42, 72728 bytes
Driver: C:\WINDOWS\system32\regplib.exe, 7/11/2008 15:39:28, 13312 bytes
Driver: C:\WINDOWS\system32\a3d.dll, 80.00.0000.0003 (English), 7/11/2008 15:51:46, 34816 bytes
Driver: C:\WINDOWS\system32\ac3api.dll, 6.00.0001.1283 (English), 7/11/2008 15:51:08, 27648 bytes
Driver: C:\WINDOWS\system32\ctosuser.dll, 6.00.0001.1284 (English), 7/11/2008 15:39:32, 69120 bytes
Driver: C:\WINDOWS\system32\ctemupia.dll, 6.00.0001.1284 (English), 7/11/2008 15:40:36, 110080 bytes
Driver: C:\WINDOWS\system32\piaproxy.dll, 6.00.0001.1284 (English), 7/11/2008 15:39:26, 64512 bytes
Driver: C:\WINDOWS\system32\ctdproxy.dll, 6.00.0001.1284 (English), 7/11/2008 15:39:44, 49152 bytes
Driver: C:\WINDOWS\system32\ctasio.dll, 6.00.0001.1284 (English), 7/11/2008 15:39:44, 46592 bytes
Driver: C:\WINDOWS\system32\ct_oal.dll, 6.00.0001.1284 (English), 7/11/2008 15:39:46, 174592 bytes
Driver: C:\WINDOWS\system32\OALInst.exe, 2.00.0003.0000 (English), 7/11/2007 02:30:34, 782336 bytes
Driver: C:\WINDOWS\system32\ctpxst32.exe, 1.01.0000.0059 (English), 3/13/2007 10:32:14, 89336 bytes
Driver: C:\WINDOWS\system32\AddCat.exe, 0.00.0000.0001 (English), 12/5/2006 14:52:40, 48400 bytes
Driver: C:\WINDOWS\system32\CTAPO32.UDA, 3/19/2007 11:58:16, 5617 bytes
Driver: C:\WINDOWS\system32\AppSetup.exe, 1.00.0000.0008 (English), 7/15/2008 01:08:00, 24089151 bytes
Driver: C:\WINDOWS\system32\APOIM32.exe, 2.05.0000.0000 (English), 8/29/2007 14:22:22, 557159 bytes
Driver: C:\WINDOWS\system32\CTxfiBtn.dll, 6.00.0001.1283 (English), 7/11/2008 15:50:28, 35840 bytes
Driver: C:\WINDOWS\system32\CTxfiSpk.dll, 6.00.0001.1283 (English), 7/11/2008 15:50:26, 45056 bytes
Driver: C:\WINDOWS\system32\Ct20xspi.dll, 6.00.0001.1283 (English), 7/11/2008 15:46:46, 10752 bytes
Driver: C:\WINDOWS\system32\CTxfispi.exe, 6.00.0001.1283 (English), 7/11/2008 15:46:44, 969216 bytes
Driver: C:\WINDOWS\system32\Ctxfihlp.exe, 6.00.0001.1283 (English), 7/11/2008 15:50:26, 19968 bytes
Driver: C:\WINDOWS\system32\Ctxfireg.exe, 6.00.0001.1283 (English), 7/11/2008 15:46:48, 43520 bytes
Driver: C:\WINDOWS\system32\devreg.dll, 6.00.0001.1284 (English), 7/11/2008 15:36:50, 32768 bytes
Driver: C:\WINDOWS\system32\eaxac3.dll, 1.01.0002.0000 (English), 7/11/2001 10:51:00, 77824 bytes
Driver: C:\WINDOWS\system32\killapps.exe, 1.00.0000.0001 (English), 7/11/2008 15:37:04, 10240 bytes
Driver: C:\WINDOWS\system32\enlocstr.exe, 7/11/2008 15:37:06, 5120 bytes
Driver: C:\WINDOWS\system32\sfman32.dll, 6.00.0001.1284 (English), 7/11/2008 15:39:32, 6144 bytes
Driver: C:\WINDOWS\system32\sfms32.dll, 6.00.0001.1284 (English), 7/11/2008 15:39:30, 104448 bytes
Driver: C:\WINDOWS\system32\data\ctd20x.dat, 7/11/2008 15:37:08, 26919 bytes
Driver: C:\WINDOWS\system32\data\CTP046AW.DAT, 7/11/2008 15:39:10, 275508 bytes
Driver: C:\WINDOWS\system32\data\CTP046BW.DAT, 7/11/2008 15:39:12, 275508 bytes
Driver: C:\WINDOWS\system32\data\CTP046CW.DAT, 7/11/2008 15:39:12, 275508 bytes
Driver: C:\WINDOWS\system32\data\CTP055AW.DAT, 7/11/2008 15:39:12, 275766 bytes
Driver: C:\WINDOWS\system32\data\CTP073AW.DAT, 7/11/2008 15:39:12, 277688 bytes
Driver: C:\WINDOWS\system32\data\CTP0460W.DAT, 7/11/2008 15:39:08, 275836 bytes
Driver: C:\WINDOWS\system32\data\CTP0462W.DAT, 7/11/2008 15:39:12, 275836 bytes
Driver: C:\WINDOWS\system32\data\CTP0463W.DAT, 7/11/2008 15:39:10, 276282 bytes
Driver: C:\WINDOWS\system32\data\CTP0464W.DAT, 7/11/2008 15:39:10, 275836 bytes
Driver: C:\WINDOWS\system32\data\CTP0465W.DAT, 7/11/2008 15:39:10, 275836 bytes
Driver: C:\WINDOWS\system32\data\CTP0466W.DAT, 7/11/2008 15:39:08, 275836 bytes
Driver: C:\WINDOWS\system32\data\CTP0468W.DAT, 7/11/2008 15:39:10, 275836 bytes
Driver: C:\WINDOWS\system32\data\CTP0469W.DAT, 7/11/2008 15:39:10, 275836 bytes
Driver: C:\WINDOWS\system32\data\CTP0550W.DAT, 7/11/2008 15:39:10, 276094 bytes
Driver: C:\WINDOWS\system32\data\CTP0678W.DAT, 7/11/2008 15:39:12, 357983 bytes
Driver: C:\WINDOWS\system32\data\CTP0679W.DAT, 7/11/2008 15:39:10, 357983 bytes
Driver: C:\WINDOWS\system32\data\CTP0730W.DAT, 7/11/2008 15:39:10, 277688 bytes
Driver: C:\WINDOWS\system32\data\CTP0760W.DAT, 7/11/2008 15:39:10, 275257 bytes
Driver: C:\WINDOWS\system32\data\cts20x.dat, 7/11/2008 15:37:08, 2091 bytes
Driver: C:\WINDOWS\system32\data\CTXFIGM.RFX, 7/28/2006 10:31:44, 41320 bytes
Driver: C:\WINDOWS\system32\data\CTXFIEM.RFX, 7/28/2006 10:31:42, 41788 bytes
Driver: C:\WINDOWS\system32\data\CTXFICM.RFX, 7/28/2006 10:31:40, 41624 bytes
Driver: C:\WINDOWS\system32\data\CTXFICBM.RFX, 6/23/2005 06:58:50, 7352 bytes
Driver: C:\WINDOWS\system32\SBXFi.ico, 2/7/2005 17:45:22, 766 bytes
Driver: C:\WINDOWS\system32\XFi.bmp, 2/7/2005 17:45:22, 3128 bytes
Driver: C:\WINDOWS\system32\ctcoinst.dll, 3.00.0002.0047 (English), 7/11/2008 15:53:26, 86016 bytes
Driver: C:\WINDOWS\system32\ctdvinst.dll, 0.05.0000.0047 (English), 7/11/2008 15:53:26, 181248 bytes
Driver: C:\WINDOWS\system32\drivers\ctdvda2k.sys, 5.13.0001.0468 (English), 7/15/2008 18:08:08, 347080 bytes
Driver: C:\WINDOWS\system32\CTAPO32.dll, 1.00.0000.0261 (English), 3/19/2007 11:05:56, 512000 bytes
Driver: C:\WINDOWS\system32\ctppld.dll, 1.00.0000.0261 (English), 3/19/2007 11:06:16, 45568 bytes
Name: NVIDIA nForce 590/570/550 Serial ATA Controller
Device ID: PCI\VEN_10DE&DEV_037F&SUBSYS_82391043&REV_A2\3&2411E6FE&0&2A
Driver: C:\WINDOWS\system32\DRIVERS\nvata.sys, 5.10.2600.0666 (English), 4/24/2006 17:52:28, 100736 bytes
Driver: C:\WINDOWS\system32\idecoi.dll, 1.00.0000.0001 (English), 4/24/2006 17:52:30, 289792 bytes
Driver: C:\WINDOWS\system32\idecoiins.dll, 1.00.0000.0001 (English), 4/24/2006 17:52:30, 289792 bytes
Driver: C:\WINDOWS\system32\NVCOI.DLL, 1.00.0000.0035 (English), 4/14/2006 14:01:20, 35840 bytes
Device ID: PCI\VEN_10DE&DEV_037F&SUBSYS_82391043&REV_A2\3&2411E6FE&0&29
Device ID: PCI\VEN_10DE&DEV_037F&SUBSYS_82391043&REV_A2\3&2411E6FE&0&28
Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_10DE&DEV_0378&SUBSYS_00000000&REV_A2\3&2411E6FE&0&68
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.5512 (English), 4/14/2008 00:06:46, 68224 bytes
Device ID: PCI\VEN_10DE&DEV_0377&SUBSYS_00000000&REV_A2\3&2411E6FE&0&78
Device ID: PCI\VEN_10DE&DEV_0376&SUBSYS_00000000&REV_A2\3&2411E6FE&0&50
Device ID: PCI\VEN_10DE&DEV_0375&SUBSYS_00000000&REV_A2\3&2411E6FE&0&70
Device ID: PCI\VEN_10DE&DEV_0374&SUBSYS_00000000&REV_A2\3&2411E6FE&0&60
Device ID: PCI\VEN_10DE&DEV_0374&SUBSYS_00000000&REV_A2\3&2411E6FE&0&58
Name: NVIDIA Network Bus Enumerator
Device ID: PCI\VEN_10DE&DEV_0373&SUBSYS_82391043&REV_A2\3&2411E6FE&0&48
Driver: C:\WINDOWS\system32\DRIVERS\nvnetbus.sys, 1.00.0002.5521 (English), 3/22/2006 14:24:02, 18944 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nvnrm.sys, 5.00.0005.5521 (English), 3/22/2006 14:23:40, 1068800 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nvsnpu.sys, 5.00.0001.5521 (English), 3/22/2006 14:23:18, 261120 bytes
Driver: C:\WINDOWS\system32\bdco1.dll, 1.00.0000.0000 (English), 3/22/2006 14:21:44, 10240 bytes
Driver: C:\WINDOWS\system32\bdco1ins.dll, 1.00.0000.0000 (English), 3/22/2006 14:21:44, 10240 bytes
Driver: C:\WINDOWS\system32\nvconrm.dll, 1.00.0000.0035 (English), 3/14/2006 21:45:22, 35840 bytes
Device ID: PCI\VEN_10DE&DEV_0373&SUBSYS_82391043&REV_A2\3&2411E6FE&0&40
Device ID: PCI\VEN_10DE&DEV_0370&SUBSYS_00000000&REV_A2\3&2411E6FE&0&30
Device ID: PCI\VEN_10DE&DEV_036E&SUBSYS_82391043&REV_A1\3&2411E6FE&0&20
Name: Standard Enhanced PCI to USB Host Controller
Device ID: PCI\VEN_10DE&DEV_036D&SUBSYS_82391043&REV_A2\3&2411E6FE&0&11
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.5512 (English), 4/14/2008 00:15:36, 30208 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.5512 (English), 4/14/2008 00:15:38, 143872 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.5512 (English), 4/14/2008 05:42:10, 74240 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.5512 (English), 4/14/2008 00:15:38, 59520 bytes
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.5512 (English), 4/14/2008 05:41:56, 7168 bytes
Name: Standard OpenHCD USB Host Controller
Device ID: PCI\VEN_10DE&DEV_036C&SUBSYS_82391043&REV_A1\3&2411E6FE&0&10
Driver: C:\WINDOWS\system32\drivers\usbohci.sys, 5.01.2600.5512 (English), 4/14/2008 00:15:36, 17152 bytes
Name: PCI standard RAM Controller
Device ID: PCI\VEN_10DE&DEV_036A&SUBSYS_82391043&REV_A2\3&2411E6FE&0&0A
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_0369&SUBSYS_82391043&REV_A1\3&2411E6FE&0&00
Driver: n/a
Name: NVIDIA nForce PCI System Management
Device ID: PCI\VEN_10DE&DEV_0368&SUBSYS_82391043&REV_A2\3&2411E6FE&0&09
Driver: n/a
Name: PCI standard ISA bridge
Device ID: PCI\VEN_10DE&DEV_0360&SUBSYS_00000000&REV_A2\3&2411E6FE&0&08
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.5512 (English), 4/14/2008 00:06:42, 37248 bytes
Name: NVIDIA GeForce 7900 GT/GTO
Device ID: PCI\VEN_10DE&DEV_0291&SUBSYS_C5833842&REV_A1\4&5E1D6BE&0&0078
Driver: C:\WINDOWS\system32\DRIVERS\nv4_mini.sys, 6.14.0011.7519 (English), 5/16/2008 14:01:00, 6557408 bytes
Driver: C:\WINDOWS\system32\nv4_disp.dll, 6.14.0011.7519 (English), 5/16/2008 14:01:00, 6108928 bytes
Driver: C:\WINDOWS\system32\nvsvc32.exe, 6.14.0011.7519 (English), 5/16/2008 14:01:00, 159812 bytes
Driver: C:\WINDOWS\system32\nvapi.dll, 6.14.0011.7519 (English), 5/16/2008 14:01:00, 425984 bytes
Driver: C:\WINDOWS\system32\nvcuda.dll, 6.14.0011.7519 (English), 5/16/2008 14:01:00, 1241088 bytes
Driver: C:\WINDOWS\system32\nvoglnt.dll, 6.14.0011.7519 (English), 5/16/2008 14:01:00, 8769536 bytes
Driver: C:\WINDOWS\system32\nvcpl.dll, 6.14.0011.7519 (English), 5/16/2008 14:01:00, 13529088 bytes
Driver: C:\WINDOWS\system32\nvmctray.dll, 6.14.0011.7519 (English), 5/16/2008 14:01:00, 86016 bytes
Driver: C:\WINDOWS\system32\nvwddi.dll, 6.14.0011.7519 (English), 5/16/2008 14:01:00, 81920 bytes
Driver: C:\WINDOWS\system32\nvnt4cpl.dll, 6.14.0010.11175 (English), 5/16/2008 14:01:00, 286720 bytes
Driver: C:\WINDOWS\system32\nvmccs.dll, 6.14.0011.7519 (English), 5/16/2008 14:01:00, 229376 bytes
Driver: C:\WINDOWS\system32\nvdisps.dll, 6.14.0011.7519 (English), 5/16/2008 14:01:00, 6582272 bytes
Driver: C:\WINDOWS\system32\nvgames.dll, 6.14.0011.7519 (English), 5/16/2008 14:01:00, 3391488 bytes
Driver: C:\WINDOWS\system32\nvmccss.dll, 6.14.0011.7519 (English), 5/16/2008 14:01:00, 188416 bytes
Driver: C:\WINDOWS\system32\nvmobls.dll, 6.14.0011.7519 (English), 5/16/2008 14:01:00, 1257472 bytes
Driver: C:\WINDOWS\system32\nvvitvs.dll, 6.14.0011.7519 (English), 5/16/2008 14:01:00, 3776512 bytes
Driver: C:\WINDOWS\system32\nvwss.dll, 6.14.0011.7519 (English), 5/16/2008 14:01:00, 2629632 bytes
Driver: C:\WINDOWS\help\nvcpl.hlp, 5/16/2008 14:01:00, 177897 bytes
Driver: C:\WINDOWS\help\nvwcplen.hlp, 5/16/2008 14:01:00, 55444 bytes
Driver: C:\WINDOWS\system32\nvcod.dll, 1.03.0000.0017 (English), 5/16/2008 14:01:00, 114688 bytes
Driver: C:\WINDOWS\system32\nvcodins.dll, 1.03.0000.0017 (English), 5/16/2008 14:01:00, 114688 bytes
Name: Texas Instruments OHCI Compliant IEEE 1394 Host Controller
Device ID: PCI\VEN_104C&DEV_8023&SUBSYS_808B1043&REV_00\4&2BE4B97F&0&5830
Driver: C:\WINDOWS\system32\DRIVERS\ohci1394.sys, 5.01.2600.5512 (English), 4/14/2008 00:16:20, 61696 bytes
Driver: C:\WINDOWS\system32\DRIVERS\1394bus.sys, 5.01.2600.5512 (English), 4/14/2008 00:16:20, 53376 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nic1394.sys, 5.01.2600.5512 (English), 4/14/2008 00:21:26, 61824 bytes
Driver: C:\WINDOWS\system32\DRIVERS\arp1394.sys, 5.01.2600.5512 (English), 4/14/2008 00:21:26, 60800 bytes
Driver: C:\WINDOWS\system32\DRIVERS\enum1394.sys, 5.01.2600.0000 (English), 8/17/2001 09:46:40, 6400 bytes
Name: PCI standard host CPU bridge
Device ID: PCI\VEN_1022&DEV_1103&SUBSYS_00000000&REV_00\3&2411E6FE&0&C3
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1102&SUBSYS_00000000&REV_00\3&2411E6FE&0&C2
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1101&SUBSYS_00000000&REV_00\3&2411E6FE&0&C1
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1100&SUBSYS_00000000&REV_00\3&2411E6FE&0&C0
Driver: n/a
DirectX Components
ddraw.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:52 279552 bytes
ddrawex.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:52 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/4/2004 08:00:00 10496 bytes
d3d8.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:52 1179648 bytes
d3d8thk.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:52 8192 bytes
d3d9.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:52 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/4/2004 08:00:00 436224 bytes
d3dim700.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:52 824320 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/4/2004 08:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/4/2004 08:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/4/2004 08:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/4/2004 08:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 8/4/2004 08:00:00 33040 bytes
dplayx.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 229888 bytes
dpmodemx.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 23552 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/4/2004 08:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 57344 bytes
dplaysvr.exe: 5.03.2600.5512 English Final Retail 4/14/2008 05:42:18 29696 bytes
dpnsvr.exe: 5.03.2600.5512 English Final Retail 4/14/2008 05:42:18 17920 bytes
dpnet.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 375296 bytes
dpnlobby.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:39:22 3072 bytes
dpnaddr.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:39:20 3072 bytes
dpvoice.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 212480 bytes
dpvsetup.exe: 5.03.2600.5512 English Final Retail 4/14/2008 05:42:20 83456 bytes
dpvvox.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 116736 bytes
dpvacm.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 21504 bytes
dpnhpast.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 35328 bytes
dpnhupnp.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 60928 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 8/4/2004 08:00:00 53520 bytes
dinput.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 158720 bytes
dinput8.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 181760 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/4/2004 08:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 8/4/2004 08:00:00 394240 bytes
joy.cpl: 5.03.2600.5512 English Final Retail 4/14/2008 05:42:42 68608 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 8/4/2004 08:00:00 76800 bytes
pid.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:42:04 35328 bytes
dsound.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 367616 bytes
dsound3d.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 1293824 bytes
dswave.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 19456 bytes
dsdmo.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 181248 bytes
dsdmoprp.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 71680 bytes
dmusic.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 104448 bytes
dmband.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 28672 bytes
dmcompos.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 61440 bytes
dmime.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 181248 bytes
dmloader.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 35840 bytes
dmstyle.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 105984 bytes
dmsynth.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 103424 bytes
dmscript.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 82432 bytes
system.dll: 1.01.4322.0573 English Final Retail 8/16/2008 19:36:51 1216512 bytes
dx7vb.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 619008 bytes
dx8vb.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 1227264 bytes
dxdiagn.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 2113536 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 8/4/2004 08:00:00 924432 bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 4/14/2008 05:41:58 1028096 bytes
wsock32.dll: 5.01.2600.5512 English Final Retail 4/14/2008 05:42:12 22528 bytes
amstream.dll: 6.05.2600.5512 English Final Retail 4/14/2008 05:41:50 70656 bytes
devenum.dll: 6.05.2600.5512 English Final Retail 4/14/2008 05:41:52 59904 bytes
dxmasf.dll: 6.04.0009.1133 English Final Retail 4/14/2008 05:41:54 498742 bytes
mciqtz32.dll: 6.05.2600.5512 English Final Retail 4/14/2008 05:41:58 35328 bytes
mpg2splt.ax: 6.05.2600.5512 English Final Retail 4/14/2008 05:42:44 148992 bytes
msdmo.dll: 6.05.2600.5512 English Final Retail 4/14/2008 05:42:00 14336 bytes
encapi.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:54 20480 bytes
qasf.dll: 9.00.0000.4503 English Final Retail 4/14/2008 05:42:04 237568 bytes
qcap.dll: 6.05.2600.5512 English Final Retail 4/14/2008 05:42:04 192512 bytes
qdv.dll: 6.05.2600.5512 English Final Retail 4/14/2008 05:42:04 279040 bytes
qdvd.dll: 6.05.2600.5512 English Final Retail 4/14/2008 05:42:04 386048 bytes
qedit.dll: 6.05.2600.5512 English Final Retail 4/14/2008 05:42:04 562176 bytes
qedwipes.dll: 6.05.2600.5512 English Final Retail 4/13/2008 22:51:34 733696 bytes
quartz.dll: 6.05.2600.5596 English Final Retail 5/7/2008 01:12:40 1288192 bytes
strmdll.dll: 4.01.0000.3936 English Final Retail 4/14/2008 05:42:08 246814 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 4/14/2008 05:42:44 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 4/14/2008 05:42:44 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 4/14/2008 05:41:56 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 4/14/2008 05:41:56 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 4/14/2008 05:41:56 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 4/14/2008 05:41:56 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 4/14/2008 05:41:56 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 4/14/2008 05:42:44 154624 bytes
mswebdvd.dll: 6.05.2600.5512 English Final Retail 4/14/2008 05:42:02 203776 bytes
ks.sys: 5.03.2600.5512 English Final Retail 4/14/2008 00:46:38 141056 bytes
ksproxy.ax: 5.03.2600.5512 English Final Retail 4/14/2008 05:42:44 129536 bytes
ksuser.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:58 4096 bytes
stream.sys: 5.03.2600.5512 English Final Retail 4/14/2008 00:15:16 49408 bytes
mspclock.sys: 5.03.2600.5512 English Final Retail 4/14/2008 00:09:52 5376 bytes
mspqm.sys: 5.01.2600.5512 English Final Retail 4/14/2008 00:09:52 4992 bytes
mskssrv.sys: 5.03.2600.5512 English Final Retail 4/14/2008 00:09:54 7552 bytes
swenum.sys: 5.03.2600.5512 English Final Retail 4/14/2008 00:09:54 4352 bytes
mpeg2data.ax: 6.05.2600.5512 English Final Retail 4/14/2008 05:42:44 118272 bytes
msvidctl.dll: 6.05.2600.5512 English Final Retail 4/14/2008 05:42:02 1428992 bytes
vbisurf.ax: 5.03.2600.5512 English Final Retail 4/14/2008 05:42:44 30208 bytes
msyuv.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:42:02 16896 bytes
wstdecod.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:42:12 50688 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
Vorbis Decoder,0x00600000,1,1,OggDS.dll,0.09.0009.0005
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.5596
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.5512
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.5596
WM ASF Reader,0x00400000,0,0,qasf.dll,9.00.0000.4503
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.5596
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.5596
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.5512
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600.5512
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5596
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
CoreCodec DynEQ,0x00200000,1,1,dyneq.cll,1.00.0002.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.5596
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.5596
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.5512
CoreCodec Audio Source,0x00600000,0,1,ccaudiosource.cll,0.05.0000.1150
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.5596
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.5596
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,9.00.0000.4503
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.5512
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
Haali Media Splitter,0x00600001,0,1,splitter.ax,
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASX file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.4503
NSC file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.5596
Windows Media source filter,0x00600000,0,2,wmpasf.dll,9.00.0000.4503
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.5596
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.5512
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.5512
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.5596
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.5512
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.5596
WM ASF Writer,0x00400000,0,0,qasf.dll,9.00.0000.4503
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
CoreCodec WPW,0x00200000,1,1,wawrap.cll,8.00.0000.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.5512
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
File writer,0x00200000,1,0,qcap.dll,6.05.2600.5512
Vorbis Encoder,0x00200000,1,1,OggDS.dll,0.09.0009.0005
Ogg Multiplexer,0x00400000,1,1,OggDS.dll,0.09.0009.0005
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
RIFF/CDXA Source,0x00400000,0,1,xcdsrc.ax,8.01.0000.0000
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.5512
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.5512
Haali Matroska Muxer,0x00200000,1,0,splitter.ax,
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.5596
.RAM file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.4503
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.5512
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.5512
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,9.00.0000.4503
CoreCodec CDDA Source,0x00600000,0,1,cddasource.cll,0.08.0000.0104
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASF URL Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.5512
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.5512
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Sections and Tables,0x005fffff,1,0,mpeg2data.ax,
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2600.5512
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.5512
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.5512
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5596
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
CoreCodec Subtitles Dispatcher,0x00200000,1,0,subdispatch.cll,1.00.0000.0003
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.5596
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.5596
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.5596
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.5596
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.5596
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.5596
XML Playlist,0x00400000,1,0,wmpasf.dll,9.00.0000.4503
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.5512
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.5596
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.5596
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.5596
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Ogg Splitter,0x00600000,1,1,OggDS.dll,0.09.0009.0005
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.5512
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5596
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.5596
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.5512
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.5512
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.5512
Video Compressors:
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.5512
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.5596
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.5512
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.5512
Xfire Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.5596
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.5596
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.5596
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.5596
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.5596
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.5596
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.5596
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.5596
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.5596
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.5596
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.5596
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.5596
Audio Capture Sources:
SB X-Fi Audio [9C00],0x00200000,0,0,qcap.dll,6.05.2600.5512
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.5596
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.5596
SB X-Fi Synth A [9C00],0x00200000,1,0,quartz.dll,6.05.2600.5596
SB X-Fi Synth B [9C00],0x00200000,1,0,quartz.dll,6.05.2600.5596
WDM Streaming Capture Devices:
SB X-Fi Audio [9C00],0x00200000,3,2,,5.03.2600.5512
WDM Streaming Rendering Devices:
SB X-Fi DMusic Synth [9C00],0x00200000,1,1,,5.03.2600.5512
SB X-Fi Synth A [9C00],0x00200000,1,1,,5.03.2600.5512
SB X-Fi Synth B [9C00],0x00200000,1,1,,5.03.2600.5512
BDA Transport Information Renderers:
MPEG-2 Sections and Tables,0x00600000,1,0,mpeg2data.ax,
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.5512
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.5512
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.5512
Audio Renderers:
SB X-Fi Audio [9C00],0x00200000,1,0,quartz.dll,6.05.2600.5596
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.5596
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.5596
DirectSound: SB X-Fi Audio [9C00],0x00200000,1,0,quartz.dll,6.05.2600.5596
WDM Streaming System Devices:
SB X-Fi Synth A [9C00],0x00200000,7,2,,5.03.2600.5512
SB X-Fi Audio [9C00],0x00200000,9,2,,5.03.2600.5512
