- Apr 28, 2001
- Kingwood, TX
I have had this board for about a year and a half and I've never seen this problem before. After it goes through the postings and the HPT370 verifies my ATA/66 HDD, It says:
Detecting IDE drives ... None
Primary IDE channel no 80 conductor cable installed
I have had this problem for about 1 week now and it gets to where it will do it every time it boots up. I have changed the cable with a known GOOD cable but no fix. I have tried to change the power connector to the HDD with a different connector from the PSU, I have even tried flashing the newest BIOS but still no fix. It sees the floppy drive in its boot up but most of the time it will not boot off the floppy and sometimes it will not even boot after posting with a disk in the floppy. I was lucky once to get it to boot off the floppy so I could just flash the BIOS then it froze after it finished flashing and I restarted. It works fine though. It must have froze after I pressed F10 to restart so it's ok. Anyone ever seen a problem like this before?? Please help if ya can. Thanks.
