- Jun 2, 2012
The PC:
Asus Formula V
FX8150
Ram Patriot Viper 3 2133mhz
PSU Corsair 750w
VGA Asus 680GTX Top
Background:
Bought new ram memory (Upgrade) to 2133mhz (max allowed for the MoBo)
The problem:
1- Installed the ram modules... pressed into the slot until "click". Turned on the PC... nothing... wont post and DRAm_LED was on.
2- Turned off the PC... Pressed the GO_button on the mobo... Nothing... same as above
3- Switched the ram modules of place... trying to turning on the pc with 1 module... nothing...
4- CLR CMOS button on the back of the MoBo... pressed for 10 seconds and then repeated steps 1 and 2 and nothing
5- Bios reset by moving the jumper as advised on the handbook... turned on the PC... nothing...
Hint: I know that the MoBo works because the old memory modules worked on that MoBo
Any ideas?
Asus Formula V
FX8150
PSU Corsair 750w
VGA Asus 680GTX Top
Background:
The problem:
Any ideas?
