I just received my new HIS HD4850 512 iceq4 turbo card today from newegg. I am really getting quite tired of computer problems lately. I am not a diagnostician.
I had a x1900xt 512 card that was artifacting all the time without high temps. I thought maybe it could have been my PSU but very unlikely. I have 2 gigs of ram and an AMD athlon 64 2.4 compaq, this motherboard should be fine for this card right? the motherboard is an ASUS A8M2N-LA. My PSU is a 500W Antec NEO_HE which I purchased used a year or two ago. I am running windows XP. I am using catalyst 9.6 as someone on this forum suggested these are the most stable for the HD4850 in windows XP. Can I trust these drivers?
I installed this card no problem. It is dead silent when I start the computer which is great and I opened to make sure the fan was actually running which it was.
It says on the box turbo edition, 650 and 2000 Mhz memory. When I run rivatuner it says 650 and 1000 for the memory so does that mean I can OC without any problems whatsoever to 2000 MHz. What is the best way to safely OC this card, I do not want any problems at all. Is CCC good enough to overclock should I just use autooverclock.
My first concern is that atitool and ati tray tools does not register the clock speeds and I cannot manually control the fan using these programs since it does not recognize the card.
When I load Ati's CCC I go to the overdrive section. It is locked currently but in the greyed out areas it says the current speeds are 500 and 1000 for the core and memory clocks. It then shows a possibility of OC'ing to 650 on a scale from 500-700 and 1000 with a scale between 1000 and 1200 ( On the box it says 2000 so how come that is not in the greyed out areas ). It also lists the fan speed in the greyed out area as 34%.
I also notice that in the first box of the hardware monitoring for rivatuner the core clock speed switches every second between 500 and 650 Mhz. What is going on? argghhh.
I load rivatuner and I can control the fan, I turned it up to 100% and the air coming out was nowhere near the amount of air that was coming out of my x1900xt. Should I be concerned that I cannot feel a lot of air with the fan on 100% compared to my old card.
My other concern is that with the fan at 25% default on my new card I tried street fighter 4 which ran on my old x1900xt at 1680x1050 ( of course it had a lot of spiking artifacts but it ran very smooth ). Street fighter crashed with my new card and I just get a black screen on the monitor but if I can remember I believe there is sound.
I try to run furmark at 1680x1050 with no MSAA and a stability test and it crashes to a black screen just like in street fighter, it crashes furmark regardless of whether I set the fan to 25% or 100% using rivatuner. My old x1900xt would run furmark at the same settings very smoothly but again there were spiking artifacts in furmark.
What on earth is happening. I bought this card thinking it would solve my problems and I thought for sure it would be much more powerful than my x1900xt. Maybe I am giving up way too early. It could be something simple.
I installed the 9.6 catalyst drivers.
One last thing I noticed. With my old x1900xt I left the side of the computer off all the time to minimize artifacting and always ran the fan at 100% during gaming. The temps when not gaming were less than 50 degrees and less than 70 when gaming.
With my new card I thought I would be able to keep the side of the tower on since it was an iceq with all these cooling features but as I sit here the temperature while doing nothing is 58 degrees according to rivatuner with the side of the computer left on not taken off.
I just ran street fighter 4 again with the fan set to 100% using rivatuner and the game runs very smoothly maxed out, I then went back into windows to check the temps of the GPU and they were around 53-55 degrees according to rivatuner which was great, I went back into the game and then it crashed and made a horrible sustained beep sound. Seriously I have had enough and would greatly appreciate some help. You have all been very good to respond so far.
My PSU should be sufficient right? 500W.
It would have nothing to do with pci-e versus pci-e 2.0 would it, I do not understand that anyways, what the difference is but I was told on this forum that my old card was pci-e and this new one is pci-e 2.0 but that it would still work.
I wish I was technical but I would greatly appreciate any help you can throw my way.
thank you.
thank you.
