- Dec 25, 2004
Background.
Machines are Win7 pro, 64bit. Joined to a domain. Roaming profiles.
Administrator profile installs a program (Vantage 6.1 by Epicor, just in case anybody has heard of it, probably not), with a couple of components, and ODBC settings manually set. Shortcut made to launch program from mapped drive. File association set first time loading program. Works as expected.
Add administrator level user profile to the machine. Log into user profile. Recreate shortcut. File association will not set. You can select the program to launch with, but once you select it, it never shows up in the panel of programs to choose from. Use a program to force file association (Default Programs Editor) Says it did it, but actually doesn't. Went in an manually edited the registry to add the file association. Now it shows up in the panel of programs to select from, but won't actually load the program when the shortcut is double-clicked.
Having task manager up and repeatedly clicking on the launch shortcut shows that the program loads for a millisecond and then goes away.
Through all this, if you log in as the profile that installed the program, it works fine. Log into 3rd profile, won't load. Uninstall and reinstall from 2nd profile and it still won't work.
I've been doing this install the same way for about 2 years now. Probably 50 computers. Win 7 64bit and Vista 64bit. No problems with any profile using it. This just started happening this last week. 2 computers so far. Though I've only done the manual editing of the registry on one computer.
The installing profile is also a domain administrator, but I just tried as the main domain admin account and it won't work there either.
Any suggestions?
Any suggestions?
