Hey guys,
This is my build log for my new watercooling system. I'm actually retrofitting my "old" setup from last summer in the hope of reducing noise level and I'm trying to get a rather clean look if possible. The concept is rather simple, my current build is mostly black (picture below), I'm going to use white components for the watercooling system to achieve a high contrast.
I'm gonna reserve the first few posts and update those as I go.
I will not post all my pics here, only the most important ones. You can check out this link for more : http://s4.beta.photobucket.com/user/Kerdal/library/Dakyris 2013 build
DISCLAIMER : This is going to be a long post with multiple pictures on the front page!
(IN PROGRESS, check back soon!)
The hardware
Existing components :
Mobo : ASUS Z77 Sabertooth
CPU : Core i7 3770k
RAM : 4x4GB Corsair Vengeance 1600Mhz class 8
PSU : Corsair HX1000
Case : Fractal Design Define XL (R1)
ODD : LITE-On iHOS104-08 Blu-ray reader
HDD : 1x WD Velociraptor 10000RPM 600GB, 2x WD Black 2TB WD2002FAEX, 1x SG 3TB
SSD : 1x OCZ Vertex 3 240Gb MAX IOPS (boot drive), 1x Agility 3 360Gb, 1x Patriot Pyro 120Gb 1x OCZ Vertex 120Gb
Monitor : 2x DELL U3011 30" 2560x1600
Cooling system : Corsair H80 with Scythe Gentle Typhoon AP15, case fans are a mix of Noctua NF-P12 (2 in front, 1 at the bottom, 1 in the side door, have a few more spares) and NF-P14 (2 in front) and that weird angled fan at the top of the case
New acquisitions :
- Fractal Design Define XL R2
- Corsair HX1050
- EK GeForce 670 GTX VGA Liquid Cooling Block - Acetal/Nickel CSQ
- EK FC Bridge Dual Parallel 3-Slot CSQ - SLI Connection - Acetal
- EK Supremacy CPU Liquid Cooling Block - Acetal/Nickel
- XSPC RX240 Dual 120mm Radiator - Custom Painted White (for the front)
- XSPC EX240 Dual 120mm Low Profile Split Fin Radiator - Custom Painted White (for the top)
- Monsoon compression fitting 1/2" ID x 3/4" OD (3 packs of 6)
- Killcoil
- PrimoChill PrimoFlex Advanced LRT Tubing 1/2"ID x 3/4" OD
- Swiftech Maelstrom with MCP35X2
- 4x Swiftech HELIX-120-BW-PWM 120mm PWM Fan (to begin with, mostly for the visible spots, may order more later if necessary or use my spare fans)
- ARCTIC MX-4 Thermal Paste
Special thanks to those who helped me review my parts selection and offered constructive criticism, especially Conumdrum and GTXJackBauer
A few notes for those who followed my previous thread.
-I decided to stick with the monsoon, mostly for aesthetic and monetary reasons. The alternatives were plain chrome or black and costed up to 3x as much per fittings. These may be harder to work with (I'll see that later and post about my experience here)
-I will start with 2 120.2 rads and see how my temperatures are. If necessary I'll add a 3rd radiator but I'm hoping 2 will be sufficient if I keep the OC mild (or open the window when it's -20°C outside haha)
Initial setup
This is what my current build looks like :
14/03/2013 - New components received
Here are a few pics of the new components
The hardware
CPU : Core i7 3770k
New acquisitions :
- Corsair HX1050
- Killcoil
Initial setup
