A while ago I found myself becoming cramped inside of the midtower case I had been using for about six months. My watercooling loop took up too much room inside the little case to be expanded. GPU cooling was out of the question. I decided to embark on a two case project to fix this problem. Its been 9 months since I started the project and I'm only starting the log now because until last month, there really wasn't much to see except for an aluminum box. I'll let the pictures do the talking.
Initial structure, made of 1/16th" Aluminum L channel, 1/8" Aluminum channel, and 22ga mild carbon steel sheet metal. Its held together with bolts and nuts.
The case turned and next to a ruler for a sense of proportion.
I have only cut out one mount for the dual PSU setup so far. I may remake the bracket as I'm not happy with the rigidity of the steel.
Here are the parts used in my TEC chiller. The pump and radiator came from PC Watercooling Shop in canada. The pump is the "$25 12v pump" that was discovered back around March.
As compared to the Thermaltake Armor case:
I'll post more in a little bit.
