Posted on: 08-06-03 10:33 PM
Sorry for the lack of posts lately. Ive been busy, and waiting for parts... and doing stuff.
But!
Today Ive got enough to post something!
Ive been thinking and brainstorming on what to do to sprice up the indiside of the cases. So I came up with an idea like I always do.
First thing was I bought a couple cans of UV paint. Its a clearcoat paint that contains Phosphorescent powder that glows under a blacklight. The paint itself is washable until covered with a sealer or clearcoat.
Paint. Plain and simple.
Next I bought several cans of Acrylic sealer. The satin finish can be used as a primer, while the glossy give it a good finish.
Acrylic Sealer. Plain and simple.
Then I chose my victim and masked off what I didnt want covered in paint.
... Paint Me!
Now, since the paint itself is clear, I really couldnt take any pics of the process. Though I can give you some hints if you try this on your own.
First off, the paint like I said is clear. The best way to create an even coat is to paint in complete darkness. Yep, darkness. Plug in a blacklight and you can see where every particle of the paint goes, its spooky.
Next, if you use an acrylic sealer on an aluminum case, use LIGHT EVEN coats. If you put too much on at once, it created small dark spots if too much was appliead at once, making the UV paint look uneven. It got soo bad in one spot, I had to strip the whole coat off with gasoline and start again.
Another thing, the more UV paint you spray on, the more paint you spray on. It doesnt get brighter or more even. Once you have covered an area, its done, more paint will be a waste, and while this paint is roughly $13 a can, its not smart to waste it.
Also, glossy clearcoat on aluminum looks sweet, and it makes the UV paint and case scratch resisitant.
Ok, heres some pics if you can make them out. Theyre of the mobo tray and case, with several coats of glossy acrylic.
Go towards the Light!
UPDATE!: Vapochill will be here on Friday! 3-day shipping from Denmark. The case panels are shipped and Im begining the design of the Vapo case panels and a Fan grill. Also, I will be ordering the rest of the comp parts this friday. So excited...
