- Jan 5, 2005
- Ormond Beach, FL.
- Thread Starter
- #41
Almost finished. All I have left to do is install the GPU power cords and SATA cables. I didn't buy long enough SATA cables. I bought them for the other case and not this one. I bought the Corsair individually wrapped PSU cables. What sucks is I had two cable that split into two 8 pin plugs. The red ones come with one that is split into an 8 pin and 6 pin. WTH? I need to order seven SATA cables; two for the 840 1 TB drives, two for each 4TB drive, two for each 3TB drive, and one for a 1 TB drive for 17TB of storage. The SSD drives go on the Intel 6GB connection. The 3 and 4 TB drives go on the other Intel ports and the 1 TB drive and Blue Ray burner can go on the Asmedia controller.
I should have taken pictures. It looks rockin with the wire management, LED fans, and LED's in the CPU block. I'm not too impressed with the Photon LED. It's not very bright. I noticed the 5mm LED's are not near as bright as the 2mm. I might try a 2mm in the Photon and see if that helps.
