I like when people tear apart my system with valid points. You don't fix what works well after all. If I had wanted only praise, I would have showed the pics to non computer people.
Thank you everyone for your input. I'm happy with the system as it is now, and I probably won't change it, mostly because any more mods I'd like to do would require ripping everything out of the case, and I don't want to do that. (cuz I'm lazy)
However, I'll probably get another lanboy in the future to do something more performance oriented. I also want to try my hand at etching stuff into a window with a dremmel.
Guderian: The drive rails are not load bearing and could be easily cut out to make room for a front mounted rad. However, you would not be able to fit it in the hole in the bezel. A short duct would probably be needed to make things work without hacking up the front of the case.
As for the bay covers, they're plastic, and have a clip on each corner that snaps into place. I'm not sure where mine went. I may have lost them, or they may be floating in my pile of useless computer crap.
mR|bUNgLe: It is not a sticker. I found an image of the logo on the net, resized it to fit on the drawer; printed it out and slipped it in.
Surreal: As far as I can tell, fluidXP is a high grade machine oil. It's slightly more viscous then water, slick in texture, and has a faint odor that reminds me of sewing machine oil; Its non conductive, anti-corrosive, and a biocide. Integrity PC says you can run it in your system for 3 years without maintenance. You can use any dye you want in it apparently, but if the dye is conductive, it will ruin the non conductivity of the fluidXP (duh).
zip22: I have yet to try reversing airflow. I'll run some tests, but temperature results might not be terribly accurate; my room temp is far from stable right now as my heat appears not to be working at all this year. (Last year I had a choice of no heat at all, or sweltering heat.)
Thanks for your input!
