- Dec 3, 2004
- VT... or MD
Spiffy!!
Krazed said:Looks very nice! I especially like what you're doing with the wiring.
Your radiator looks like an oil cooler to me, but its hard to say. They're fairly general purpose. Looks nice though!
One suggestion however, since you have a DFI Board like mine, I'd recommend swapping out the chipset heatsink/fan on there with this.http://www.svc.com/vc-re.html The stock ones are known to die, rattle, overheat.
I use it on my DFI Board, and it dropped my temps way down. Originally, I replaced it due to a rattling, but it helped more then fixing just that!
Just a suggestion! Other then that, good work!
Suma said:Thanks,
I'll look into your suggestion, I recall having a some high temps in the summer. How noisy (db wise) is that hsf?
Suma.
Krazed said:Its almost inaudible even at 5500rpm (mine is running at that now). I'd suggest using one of the software fan controllers to control it.
I forgot what I'm using at home but it works great! I'll send you the link when I get home tonight. Works quite well, and is easy to use and runs in the background almost unnoticeable.
Suma said:Cool. Thanks.
I'll go and grab one of those. Hopefully tomorrow morning
Suma.
Krazed said:No problem!
Just make sure it's the same model, as it fits the mounting pin holes perfectly!
Also, wouldn't be a bad idea to put a little Arctic Silver on there.
Suma said:11-13-06:
It's been too long since I updated.
I listen to Krazed whom suggested ti upgrade the original DFI nb cooling.
