I have to say I'm very impressed and pleased with this setup. I'm running a P4 Prescott that runs hot as you know what. With this setup
I'm idling at 36c-39c in the hot California afternoon with room temps of 84 Fahrenheit!!! That’s insane for a Prescott!!! My last setup was idling at 39c to 45c with a tornado blowing hot air out of the case.
With this new setup I'm maxing at 41c-43c in the hot afternoon!!! That is after Prime 95 and 2hours of gaming. My previous setup was maxing at 48c-52c, again, with a tornado blowing out hot air. I've also increased my stable overclock from 3.6 to 3.8 and I don't even have to use the tornados.
The improvement I'm most impressed with is that my 9800pro’s overclock has gone from 420mhz to 460mhz with absolutely no artifacts or crashes, now that’s amazing!
The problem with my last setup is that the water went from the CPU to the NB and then to the GPU. That held back my GPU overclock. By the time the water got to the GPU it was boiling hot. Now that the water goes from the BIX II through the CPU, then to the 80mm rads and through the NB, then enters the BIX for further cooling before it travels through the GPU has helped me reach a higher overclock with my 9800pro. And in the long run that’s what it’s all about. That’s the main reason I switched from air to water with my first case.
The setup is extremely quiet even with all the fans I have moving air through the rads. And on top of that it’s a beauty to look at
. I hope I've stirred up some creativity in someone who has followed this tread. I'm eager to see what others come up with.
