- Jun 10, 2011
- Connecticut, USA
Okay so I ordered everything (Some from newegg, some from other suppliers).
- Scythe Kaze Master Pro 5.25 Fan Controller
- 6x Scythe Kama Flow 2 SP1225FDB12H 120mm Case Fan
- 2x Scythe Kama FLEX PWM 120 SA1225FDB12H-P 120mm Case Fan (Push/Pull for Heatsink)
- GELID Solutions 350 mm PWM Y Cable Model CA-PWM (To accommodate Push/Pull with MOBO CPU header)
- Prolimatech Megahalems Rev.B CPU Cooler
- Expandable Braided Cable Sleeving (To tidy up the ugly wires)
- OKGEAR 24" SATA 6 Gbps Cable, Straight to Right Angle W/Metal Latch, Black, Backward Compatible with 3 Gbps and 1.5 Gbps (To get rid of some of those ugly red SATA cables)
I have two questions:
1) What TIM should I use (Prolimatech Supplied TIM, AS5 laying around (Purchased on 12/29/2010), or anything else suggested)? Also, what application method should I use?
2) Should I mount this in a north/south or east/west orientation (More Info: I'll have 1 rear exhaust and 2 top exhausts surrounding it)
Thanks,
-meeps
Thanks,
-meeps
