- Mar 13, 2011
- West Bend/Milwaukee, WI
- Thread Starter
- #61
Page Fault BSOD
Okay, so I tried 250MHz again, and again upon stress testing it bsod'd on me giving me a 'page file in non paged area', which from research online happens when it attempts
to move information from the paging file to the unpaged (reserved for essential system functions) area of the RAM. I then tried 245MHz, and during stress testing it gave me
a bsod that read something like "a clock was not returned to a processor core within the required interval" or something to that effect. So, I'm assuming if it is possible to OC
it any higher I have to adjust the RAM timings again? Thinking I should just shut up and be happy with 3.6GHz on the processor... but the 3.75GHz oc that ups the HT Link
back to 2000MHz and the RAM back to 666.7MHz just looks so appealing... lol. I suppose though, a fried motherboard looks way less appealing. I did not however try upping
the voltage anymore on the RAM... QuietIce, you mentioned starting at the default +.05, currently I am at 1.52v (default 1.5v), could upping that more help maybe with the
bsod's I got? EDIT: Upon further research online the bsod I got "clock interrupt was not returned to a secondary processor in the required interval" is most associated with a
bad processor core... others have found if they go in manually and lower the setting on the bad core that they get no more blue screens, but being I'm already oc'd I doubt
the core is bad, it just would appear that one of the cores does not want to go above 3.6GHz, which is more of an overclock than I thought I'd get. So I guess, up the RAM
voltage a bit more and try again, or accept the 3.6GHz as all the higher she's going to go and leave it be? If what I read online is correct however, and it is 1 of the cores that
caused the bsod, then I probably don't want to risk any further damage to said core.
