- Nov 4, 2011
- Melbourne, Australia
Hey all,
I am new to the site, and I have already had a look through all the forums and got some inspiration for my next project - building a custom water loop.
I have already dabbled in water Cooling, when I first built my current rig, I installed the Thermaltake ProWater 880i (I should had read the reviews first!), and then after one of the fans broke at 5pm on a Friday afternoon (second day in to battlefield 3) I hurried down to my local PC shop, which was limited in the water Cooling department, and bought a Antec Khuler h20 920. This has been sufficient for the past little while, because I have clocked back to stock standard (I will explain later).
So short story long, I am due to build up a new WC unit, with 2 loops, one for CPU and 1 for GPU. I will go through everything I am expecting to purchase (I am up to AUD$1763.40, with some new sleeved cables to pretty up the inside and a new PCI-Express SSD)
But first of all I will go through my current specs, so here goes..
Thermaltake Level 10 GT (black edition)
Gigabyte G1 Sniper (Rev 1.0)
Intel i7 960
12gig Patriot Viper II Sector 7
2X Gigabyte GTX580 in SLi
OCZ SSD
4X WD Green 2TB
LG Bluray player
Antec TruePower Quattro 1200
So first thing is first, the Res, pump and water blocks.
Reservoir - Koolance RP-452X2
Pump - Koolance PMP-450 (X2)
CPU Block - EK-Supreme HF EN Nickel
GPU Block - EK Full Cover VGA Block EK-FC580 DCII Acetal+EN Nickel (X2)
The reason I went with these pumps is because the fit directly into the res and hide away in the 5.5" bays. The water blocks are the best of the bunch that I have available.
Next up The Radiators. This is where the tricky part begins. I really like the black ice range of rads, they are a good choice for fans that don't sound like B52 bombers. I have an image here of sf_rodrigo's Level 10 set up (with his permission)
My idea for this is having a similar set up, but the radiators I have chosen are pretty much double the depth of his; (Black Ice SR1 120 Radiator, Black Ice SR1 240 Radiator)
So, as per the picture inside the case, with the Rad 1 installed, Rad 2 will not fit in place if double the depth. My solution is putting Rad 2 on the outside of the case in the same position, therefore being able to have 2 fans for push/pull. Any thoughts on that?
The map would be; Green loop Res>Pump>Rad1>Rad2>GPU1>GPU2>Res.
And for the Blue loop Res>Pump>CPU>Res.
To me that looks pretty good at the moment, but I do want to get some advice on how to better the set up if needed and also what fans should I get? I have been looking that the Noctua NF-P12 120mm Fan and the CoolerMaster 120mm Excalibur PWM Fan (I am not sure if the Noctua has controllable fan speed?) and then just a cheap 3.5" drive bay fan controller.
The main other source of confusion is how many fittings I will need for everything. What fittings go into the rads? how many will I need for all the blocks? Should I bother with a solid SLi block connector, or just use 2 fittings and a small amount of tubing? Should I get EK ones for the block, and then Koolance ones for the Res (keep it all in the same brand?). It is all those small things that confuse me and I can never get a straight answer from trawling through the forums..
If you have reached this line, then Thanks for reading! (I would have given up hours ago) Lets see this thread turn from Idea to Project, although it might take a while, as we have a baby due in a few months!
Intel i7 960
OCZ SSD
4X WD Green 2TB
LG Bluray player
