- May 26, 2004
- Lethbridge, AB
martinjon666 said:LOL...Thanks for all the ideas guys. Newbinerd, I work in a cabinet shop, i cut out a 120mm circle at work and used plastic inserts for the screws so all i have to do is drill the four holes for the mounting screws then mount my template and using a flush trim router bit......Ta Da!.... 120mm fans coming up!
WWUHHHHH!!!!!!! Luuucckkyyy!!!! Anyways.. the thing is the holes and especially the fans themselves don't have exactly 120mm holes... if u just cut out a 120mm hole.. that hole might be too big for the fan.. what i mean is that there will be abit of space showing up on the side of the fan.. does that make sense??? Like i have a 120mm fan here and it measured (the hole in the fan itself and not the # x # measurement) 11.2cm.
well.. good luck!!! Lucky bum!!!
