The attachment describes what I've done with my Ryzen systems. In both cases, Taichi X370/1700X and the Hero VII/2700X they do not do what I think they should when Overclocked and Idle. Both of them are running the latest greatest BIOS, both are OC'd via Pstate0 and both of them are very stable at 3825 and 4150, respectively. The only issue I have is the 1700X reduces the Vcore when Idle but not the CPU multiplier and the 2700X reduces the CPU multiplier but not the Vcore when idle!
I have post this issue on the ROG and the TweakTown forums but have not found anyone with the same problem or someone with a solution. I cannot believe I'm the only person screwing around with these system configurations in the Ryzen world that has this problem(s)? I know it's not a major issue since both systems tend to cool down to a normal temperature <30C when idle but I have several OC'd Intel 4790K based systems that down clock the CPU and Vcore when I idle so.. I was expecting AMD Ryzen to act the same?
The Hero VII/2700X system does act the way it should when everything is set to default. The BIOS lowers the Vcore and CPU multiplier when idle. The only problem with that, in my opinion, is the system pushes 1.45+Vcore every time it wants to boost the CPU to 4350 on one core. However, As soon as I increase the Pstate0 FID to whatever the system locks the Vcore but at least the BIOS stops trying to run one core at 4350 every time Windows 10 has a request.
Is all this normal for Ryzen BIOS's or is there something I'm missing that needs to be changed?
