- Mar 17, 2010
I'm planning a new build, which will be watercooled.
Here's what I have so far:
1) ASRock Z77 Extreme6
2) Intel Core i5-3570K
3) G.SKILL Ripjaws X Series 16GB F3-1600C9D-16GXM
4) PowerColor AX7950 3GBD5-2DHV4 Radeon HD 7950 Boost State 3GB
5) Fractal Design XL R2
Now there's a couple of things I have to confirm with the watercooling, such as radiator sizes(the fan mounts are up to 140mm) Id like to have a 420 rad on top(which would require modding) and a 280 in the front. Probably overkill but this is more of a showpiece and my primary gamer, but I will be doing much more than that on the rig such as 3D and photo editing. Another thing I desire highly is a fully modular PSU. I want to be able to mod the cables(considering heatshrinking each cable to a specific color then sleeving them) Cable management will be a must for this build as it needs to look as clean as possible without extra cables laying about.
Here's a couple of PSUs Ive considered so far for this build:
1) SeaSonic SS-520FL
2) SILVERSTONE ST55F-G
3) CORSAIR AX760
I was considering This but the thing that draws me away from it is the 24-pin and 8-pin which are hardwired. One final thing is I'm trying not to spend too too much on the PSU $150 is the max I'd like to spend if possible.
3) CORSAIR AX760
