- Jun 6, 2002
i can use to upgrade a friends pc... im really not liking amds cpu list part, why cant they just list the cpu by socket. i mean the specs says its a sempron 140, tells me its a AM3 cpu. do a search on google and AM3 cpu list, dont get anything off amd's site. then trying to wade through the posts on toms about cpus, no one lists which ones will work.
if you want links
https://support.hp.com/us-en/produc...ries/4269980/model/4337143/document/c02550047
https://support.hp.com/us-en/produc...ries/4269980/model/4337143/document/c01701270
Ok so the issue is i have used the chipset name to find a supported cpu list but nothing. i havent emailed HP since i dont have the sn number, they are telling me on the phone they want the sn before i can get a cpu list for the computer. :banghead:
anyway, i need help in finding AM2+ or AM3 dual core cpus that will work in the motherboard/computer. i keep hitting walls, post after post with dead links in toms to 3 and 4 core cpus from others asking for help. a full list of cpus would be nice so i can pick one and look up prices, see if that fits the budget.
thanks for anyone that can help me out, cause after 3hrs off/on im out of steam on this.
if you want links
