Metaxas (Mar 20, 2001 01:54 a.m.):
Where I live, we have a Lowes. What kinda flow rate would you suggest, maybe 100GPH? And also, what about those round clamp things that can go around the house, and you can tighten it up with a screw, and it keeps the hose on there for sure...where do I obtain some of those. Dumb questions I know, however, I don't work much with that kinda stuff.
You say, a pond pump, or waterfall pump...ok, will the box say how far it can lift also? I plan on running my reservoir outside of my case (not interested in portability) so its going to be a gallon container of somekind. Thanks for the help bro...heehee... ;D I'll get this box up if it kills me...and you know what's bad...if these problems had not come up with caseetc...my new system most likely would have been running 3 days ago. DOH. But that's okay....lowes it is.
## Hey if you've got a Petworld, or Pet warehouse that is where I picked mine up it's a MaxiJet 115 GPH at 5' Lift, got it for 25$ So check it out you can get some good deals I have also seen the heavy duty MagDrive pumps at the pet store too. Look for what they call a powerhead, they will tell you whether they are submersible or Inline, so check em out and you should be able to find a bargain. Stop in there and see what you can find. You might be suprised! =) ##
