- Jun 22, 2012
When fans run in series, such as in a Push-Pull configuration, and the fans have different CFM is the total CFM the average of both (or however many you have in the series) fans?
That said a higher CFM is best on the push side.
However, that being said, if two fans are in series with no heatsink would the slower fan somehow bottleneck the faster one?
You would think so, but not always the case again
I took an XAF-F1255 and the Scythe Ultra Kraze. 90cfm and 133cfm fans.
I used them both in a push-pull setup on my Aegir. Swapped them to see if there was any difference. None. Under full load with Prime95 the temps were within 1C of eachother with the two fans in a push-pull and swapped for comparison.
Not talking about on my radiator, i dont have liquid cooling. I am talking about on my Xigmatek Aegir heatsink for my cpu.
you know that silver thing right in the middle of your air cooler?
that is a radiator. ... just in case you didn't know.
now reread what I wrote.
if you OC your CPU any further, the fan will matter.
but of course, not suggesting that you should, if you are happy with the performance, then great.
Actually a radiator has some kind of liquid that runs through it, so therefore its a heatsink to be exact, even tho it may act as a radiator or serve the same purpose as one.
And ive taken my cpu to 4.8-5.0ghz and it still didnt matter. The other fan didn't help much at all. I just wouldnt want to have to super load hovercraft sound to have it 1-2C cooler on the core temps. Not worth it IMO
A radiator is a heat exchanger, regardless of medium.
By the way, air = fluid
Straight from the dictionary
1.
a person or thing that radiates.
2.
any of various heating devices, as a series or coil of pipes through which steam or hot water passes.
3.
a device constructed from thin-walled tubes and metal fins, used for cooling circulating water, as in an automobile engine.
1.
Well, guys, don't play with words like this, ok?
In this world, a radiator is the stuff we use for WC, otherwise we say "heatsink".
And don't start with "Yes, but the meaning of words...blah blah blah..." please, ok?
Do you want the new member to leave the forum already?
Is he not "elite" enough for you?
