BandonStorm
- Oct 18, 2013
- Doha, Qatar
Hey Guys,
I have put 4 Corsair SP120 Fans on my Cooler Master Seidon 240m radiator in push pull configuration. Can I connect the 4 fans to the CPU_Fan socked on my motherboard (Gigabyte Z87X-U3H)?
If not, how can I do this? Is there a way to split the power from the PSU while controlling the fans from the CPU_Fan header? I have tried to find information by myself but its pretty confusing when it comes to Fan Controllers.
Also all the Pins on the motherboard are 4pin. I have removed two of the fans for now and connected the fans on the radiator to the CPU_Fan header with a Y splitter (Was scared to connect daisy chain all four fans.) CPU runs at 85C max with IBT.
This seems to be the kind of control I'm looking for, but its out of stock http://www.swiftech.com/8-waypwmsplitter.aspx .
Please throw in your suggestions and help me finish my first liquid cooler build
